Re: Hazard Switch gone bad, no lights. [Re: Trailmonkey] #1105802 11/06/20 12:37 AM
Trailmonkey Offline OP
That would be perfect. I can definitely use that.
P.M. me info.
91 (Gen1) Monty, 3.0L V6, Auto 4 Door.
Disabled Driver.
Re: Hazard Switch gone bad, no lights. [Re: Trailmonkey] #1105803 11/06/20 04:59 PM
Anyone else got broken hazard switches let me know. I messed up on mine but now know what to do and fix them, you wont be able to use the hazard flashers but all the rest will work.
Ill fix them for $15 plus shipping.
Disabled Driver.
Re: Hazard Switch gone bad, no lights. [Re: Trailmonkey] #1105804 11/07/20 03:23 AM
Alan Casetta is getting about $115 for new hazard switches
PN: MB330277
Re: Hazard Switch gone bad, no lights. [Re: Trailmonkey] #1105805 11/07/20 01:30 PM
I just want an old one to fix up, set it to the hazards off position and epoxy that bad boy so it wont move..
Started to do mine that way but thought i could just jump the wires that the contacts made only. Removed the rest. Got the turn signals working but no brake lights. : (
Disabled Driver.
Re: Hazard Switch gone bad, no lights. [Re: Trailmonkey] #1105811 11/17/20 12:33 AM
Well got my lights working, less hazard flashers. Simple mistake i made but thanks to Chad ive got it worked out.
If anyone else has a bad switch, or no switch and needs their brake lights working again let me know, its a super simple 2 jumper wires and you will be back on the road even with no actual switch.
Disabled Driver.
Re: Hazard Switch gone bad, no lights. [Re: Trailmonkey] #1106308 06/04/21 01:40 PM
JMQ12 Offline
I have the same problem so would greatly appreciate knowing the fix. Once you jumper will both brake lights and turn signals work again? Thanks,
'91 Montero RS unmodified
Re: Hazard Switch gone bad, no lights. [Re: Trailmonkey] #1106309 06/04/21 10:15 PM
There really aren't any. Facebook is killing forums because it's made for a 4th grader. So much information is lost on that stupid platform. If you wanted to run a bite to the back you could separate the brake light from the turn signal where it comes into the column switch. The guys using the JDM lenses do that to get a separate signal for the amber turn/red stop light.
Re: Hazard Switch gone bad, no lights. [Re: JMQ12] #1106311 06/06/21 11:38 PM
PM sent.
Disabled Driver.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6263 MB (Peak: 0.7250 MB) Data Comp: Off Server Time: 2026-06-17 13:43:57 UTC
