KM145: What have I done wrong? #1105874 12/28/20 05:45 PM
TresMon Offline OP
Dodge Raider, 5 speed manual:
I replaced the transfer case chain. Reinstalled the tranny/T-case in the vehicle and now the trans is STUCK in 3rd gear.
So I learned that only and idiot does all the work to install a transmission before seeing if it shifts correctly.
So what have a done to cause this tranny to be stuck in 3rd gear? something about the linkage?
Thanks. Happy new year,
Tres
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Welded front,tight LSD in the rear
Removed bump stops
4'x6' roof rack
10k. Lb. winch on receiver hitch/custom bumper
100 amp alt
CB radio/AC inverter
S.Winch hubs
Enormous RV battery
Re: KM145: What have I done wrong? [Re: TresMon] #1105876 12/29/20 02:24 AM
You removed everything to do the job on the bench?
Stuck in third...so the shift lever is all the way back? Have you tried gently pushing the shifter part forward with a pry bar?
This is a new one, Tres.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.5895 MB (Peak: 0.6381 MB) Data Comp: Off Server Time: 2026-10-22 12:14:31 UTC
