Some of you have been reaching out to us to find a Braided Stainless Steel Brake Line solution for 2001-2004 Mitsubishi Montero Sport's. Good news is its finally here. Depending on if your truck comes with Drum or Disc brakes out back, its either a 5-7 line upgrade. They are also on Sale too!
B-Line Performance 2001-2004 Montero Sport Braided Stainless Steel Line Set![[Linked Image from static.cargurus.com]](https://static.cargurus.com/images/site/2008/10/05/11/52/2001_mitsubishi_montero_sport_limited_4wd-pic-48982-1600x1200.jpeg)
Of course our lines are assembled in the USA and meet DOT Compliance for on-road use. They are further individually pressure tested to over 3,000 PSI (more than 3X what your system will experience) and inspected before being approved for shipment. Sets are built to OEM specs and orientation, to further guarantee fitment and life of our product. Set comes with new retainers.
Do not be confused by budget priced, or over seas, lines that do not meet DOT Compliance. Approved brake hose manufacturers must self-certify that their products meet the performance standards of Federal Motor Vehicle Safety Standard (FMVSS)106. Our lines meet FMVSS106 Standards and have the proper identification to prove it. This identification is found in 3 parts; 1) on our lines, 2) on our collars, and 3) on our end fittings. If those identifiers are not on your lines then they do not meet the FMVSS106 Standard and are not DOT Compliant. Ensure that you get the highest quality lines and piece of mind.
Other applicable trucks:
Mitsubishi Pajero Sport
Mitsubishi Challenger
Mitsubishi Shogun Sport (United Kingdom)
Mitsubishi Strada G-Wagon (Thailand)
Mitsubishi Nativa
Beijing BJ2025
Experience the Benefits of B-Line Braided Stainless Steel Brake Lines!
Reduce overall braking distances.
Eliminate pedal sponginess under heavy braking, giving you more precise feel.
Immediate and more accurate brake pedal response.
Compatible with all OEM manufacturer brake fluids.
Produce stronger lines that are more resistant to abrasion and natural elements.
Meets DOT Compliance, and Federal Motor Safety Standard (FMVSS)106.
