Mitsu shift shaft, Sport or Gen 3
#1106180
04/05/21 12:10 AM
I am in need of a shifter shaft that passes through the side of a computer shifted automatic. This is the shaft the cable arm mounts to and passes through the selector switch. Mitsu Pn, MR336341
This shaft should interchange with most all Asian computer shifted Automatics used in Jeeps, Toyotas, Hyundia and Mitsubishi RWD platforms. Might be the same in BMW and Volvos as well as others.
Some repair shop before me welded the shift arm on resulting in the selector switch being damaged.
I am striking out on new sources, not done trying though.
Re: Mitsu shift shaft, Sport or Gen 3
[Re: OldColt]
#1106199
04/08/21 12:07 PM
I have ordered a new shaft coming out of Japan, shaft is cheap, shipping is stupid.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.5914 MB (Peak: 0.6392 MB) Data Comp: Off Server Time: 2026-10-22 02:14:48 UTCValid HTML 5 and Valid CSS
