replace master cylinder #1106192 04/07/21 05:29 AM
nvmonty Offline OP
I want to remove the windshield washer reservoir to make room to work on the brake master cylinder on our '90 Gen I. It looks like the washer reservoir should just lift off the bracket but it doesn't move and I don't want to break the 31-year old plastic reservoir. Is there something else holding the reservoir or should it just lift up off the bracket?
90 LWB RS: 3 L/mt, JBaker springs, bushings, swaybars. KYB shocks tweaked, 134k mi, original owner.
97 LWB SR: SOLD Sep. 2014 131,006 mi: running boards removed, BFG 31x10.5 AT/KO tires, Air locker, AirLifts, KYB shocks, Cibie fogs, 3rd owner.
Re: replace master cylinder [Re: nvmonty] #1106193 04/07/21 11:49 AM
It should lift up. Might want to dribble a little dish soap down where the metal bracket slides in and rock the reservoir a bit to break the friction.
Re: replace master cylinder [Re: nvmonty] #1106194 04/07/21 05:30 PM
nvmonty Offline OP
Thanks OldColt! That's what I thought but I did not want to force it....
Re: replace master cylinder [Re: nvmonty] #1106195 04/08/21 03:21 AM
nvmonty Offline OP
Turns out there are two detents at the bottom so if one pulls straight out on the bottom and then lifting it slides up. Takes some effort at the old plastic is not as flexible. But it is surprisingly tough for a vehicle made in 1989!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6035 MB (Peak: 0.6592 MB) Data Comp: Off Server Time: 2026-05-29 17:25:23 UTC
