JK Check Engine Light - P0300 #1106529 11/09/21 12:31 AM
4x4Wire Offline OP
One morning I slid behind the wheel of my Jeep, slid the key into the ignition, and tried to start the engine. I was met with the ominous clicking indicating a low battery. And, the dash was ablaze with a series of warning lights.
First step, get the engine started. I carry an emergency battery pack that provides the necessary power to start a vehicle engine. Within minutes, the engine was started and running very rough. The dash warning lights were reduced to two, the Electronic Throttle Control warning and the Check Engine Light.
The ETC warning was a simple fix with a few key clicks and timed pressing the throttle pedal. While that warning light was quickly cleared, the Check Engine Light remained on and idle remained very rough.
My INNOVA 5310 code reader revealed a stored trouble code - P-0300. By definition, that code indicates multiple random mis-fires. The list of possible causes was long, some easy and some not so easy. A series of repairs were in order, starting with a new battery and tuneup.
Read more at: http://www.4x4wire.com/entry/jk-check-engine-light-p0300
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: JK Check Engine Light - P0300 [Re: 4x4Wire] #1106534 11/15/21 02:53 AM
Interesting, these pesky lights and little failures of doom.
Re: JK Check Engine Light - P0300 [Re: rxinhed] #1106536 11/17/21 09:08 AM
4x4Wire Offline OP
Those pesky lights can be indicators of doom. They do point to a potential problem, often not the real problem.
As I found, a tune-up solved the issue. My next step was more complicated involving fuel pressure and fuel injectors.
John Stewart
Editor - 4x4Voice
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.5938 MB (Peak: 0.6477 MB) Data Comp: Off Server Time: 2026-10-21 19:47:44 UTC
