3.2l DOHC owners... #124301 02/01/03 06:54 AM
Trooperfreak Offline OP
What do y'all think, in a broad sense, of this engine? I'm looking at an older 2nd gen Trooper with high miles(over 100k). It sounds OK, but I don't know what to look or listen for.
BTW, I've done searches in both forums and only come up with the "ticking" reference that seems to start about 3,000 miles after an oil change. What's up with that? Sorry to sound stupid. All I've owned are 2.3's and 2.6's, both of which I think are bulletproof (with good maint.)
Thanks!
'86 Isuzu Trooper II, Durabak coated exterior, 4ZE1 2.6L, Weber 32/36, K&N, Rancho RS9000, Indy4X shackles, BJ flip/T-bar crank, Pacesetter header, dual core radiator, Mazda seats, 31x10.5 BFG TAKO's
Re: 3.2l DOHC owners... #124302 01/31/03 08:02 PM
*EDIT*
DOH disregard this, your asking about the DOHC. I got the SOHC.
Engine wise I can't complain, however aftermarket mods are almost non exhistant. Not sure if thats the case on the 3.5 as well.
At least for the 2.8 there seem to be several mods available for increased HP.
I can say Ive got 72K (not very much) on my 96 but I drive it HARD change the oil reguarly and have 0 problems with the engine.
<small>[ January 31, 2003, 02:03 PM: Message edited by: DaveFL ]</small>
Re: 3.2l DOHC owners... #124303 01/31/03 08:24 PM
N
Nazrat Offline
I have 167k miles on my 1994 3.2 DOHC. It uses almost no oil, and has no annoyances that I can think of.
Because of the nature of the lifters on the DOHC engines vs. SOHC engines, the DOHC engines aren't prone to the same ticking problems.
DOHC:
<img src="http://www.plan...-th.jpg" alt=" - " />
SOHC:
Notice the complex rocker arm system on the SOHC? That contains the hydraulic lifters, which can get dirty and cause the ticking sound. In the DOHC each cam sits right on top of the valve stems, with just a solid "shim" between the cam and the valve stem. Nothing to get dirty and possibly collapse.
There are a few more pics of 3.2 engines at:
http://www.planetisuzoo.com/articles.htm/76
-Tad
1994 Trooper. 3.2 DOHC/auto. 4.77s,3xARB, OME 919HD springs. 34" Swamper LTBs
2001 Trooper "stock" <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: 3.2l DOHC owners... #124304 02/01/03 03:37 AM
And the number 1 reason to go with a 3.2 DOHC motor is.....
*drumroll*
Supercharger <img border="0" alt="[Satan]" title="" src="graemlins/satan.gif" /> Muahahahahah....
'nuff said.
Jim
Re: 3.2l DOHC owners... #124305 02/01/03 04:12 AM
yeah that's right dohc does not tick and you can put a superchager on!!!. <img border="0" title="" alt="[Smile]" src="images/icons/smile.gif" />
Re: 3.2l DOHC owners... #124306 02/02/03 04:29 AM
snowrodeo Offline
don't kid yourself, the DOHC does tick. it has hydraulic valve lash adjusters, similar to lifters but not technically the same. shake a bush and twenty DOHC owners with ticking problems will fall out. having said that, most of us have had good luck flushing and running synthetic oils that in many cases have cured the ticking problems. i use mine to tow my 3,000# boat and my pop-up with no trouble. it's torquey and loves to run hard. many have had trouble with intake gaskets but apparently that's not too hard to fix either.
97Rodeo Rancho9ks/Aisins/3.2L SOHC/M1 only
Proper Prior Planning Prevents P*ss-Poor Performance--Maj. R.T.Spooner USMC(Ret.)
Re: 3.2l DOHC owners... #124307 02/02/03 03:27 PM
Snowrodeo - Not sure how your figure the DOHC 3.2/3.5 has hydraulic lash adjusters??? There's nothing at all hydraulic about them. They are a mechanical shim & bucket design that has to be adjusted manually.
Re: 3.2l DOHC owners... #124308 02/04/03 06:30 AM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by snowrodeo:
<strong>don't kid yourself, the DOHC does tick. it has hydraulic valve lash adjusters, similar to lifters but not technically the same. shake a bush and twenty DOHC owners with ticking problems will fall out. having said that, most of us have had good luck flushing and running synthetic oils that in many cases have cured the ticking problems. i use mine to tow my 3,000# boat and my pop-up with no trouble. it's torquey and loves to run hard. many have had trouble with intake gaskets but apparently that's not too hard to fix either.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">I thought the 97 Rodeo was a SOHC. My understanding was they put the 175 hp version in the Rodeo and base Troopers until 96 (the DOHC was an option in Troopers only from 92 to 95). Then all models got an upgraded 190 HP version of the SOHC 3.2 for 96 and 97. The first DOHC Rodeo was the 1998 205 hp version.
Might be wrong though, memory sucks lately. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
<small>[ February 03, 2003, 02:34 PM: Message edited by: Paul E ]</small>
Re: 3.2l DOHC owners... #124309 02/04/03 06:57 AM
N
Nazrat Offline
At least in the Trooper, a DOHC engine was optional in at least 92 and 94. I'd guess 93 as well, but I haven't seen one. I know 92 and 94 because I have a 94 and my dad has a 92.
They are rated at 190HP.
-Tad
Re: 3.2l DOHC owners... #124310 02/03/03 07:57 PM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans"> Origianally posted by: Nazrat
At least in the Trooper, a DOHC engine was optional in at least 92 and 94.</font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">I've not heard of any Isuzu DOHC 3.2's prior to 1998. Like Paul E. says, they souped up the SOHC 3.2 a bit in the mid 90's bringing it up from 175 to 190hp. Any pre '98 DOHC 3.2L in the USA is news to me.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6336 MB (Peak: 0.7570 MB) Data Comp: Off Server Time: 2026-11-16 08:47:11 UTC
