Towing with Trooper #128103 09/18/02 05:40 AM
Paisan Offline OP
Ok folks I just got back late last night from towing DougHs Montero that lost a tie rod end back from upstate ny on a flatbed trailer. Here are a few notes:
o Always remember to check the Tire Pressure of the trailer from uhaul
o 6600lbs + is easily doable with a stock driveline of the trooper at 60-65mph, don't know why anyone wants a supercharger for these rigs
o OME springs and Rancho 9000 shocks help imensely
o Hidden Hitch also performed flawlessly
-mike
97 Rodeo -> 00 Trooper LS (too many mods to list)
88&91 Subaru XT6 -> 92 Subaru SVX
My Websites: http://isuzu-suvs.com
Re: Towing with Trooper #128104 09/17/02 09:15 PM
Chris Perosi Offline
Isuzu Staffer Emeritus
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by paisan:
<strong>o 6600lbs + is easily doable with a stock driveline of the trooper at 60-65mph, don't know why anyone wants a supercharger for these rigs</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Cause if you have the money, then WHY NOT? Who couldn't use a little more power? <img border="0" title="" alt="[Wink]" src="images/icons/wink.gif" /> I agree with you, it doesn't really NEED it... But if you can afford it, why not? <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
Just as an FYI -- I do believe the stock clutch in the 98+ Amigo/Rodeo (very similar power to the Trooper you're referring) isn't quite up to speed on towing that kind of weight all that far. Perhaps the engine is up to the task, but the clutch is a little weak for that... I know this isn't completely related since it's a completely different tranny, but worth noting since it's a similar power setup engine-wise...
-Chris
Chris Perosi
Isuzu Editor Emeritus
OutdoorWire, Inc.
Re: Towing with Trooper #128105 09/17/02 09:34 PM
4
4Play Offline
Did the flatbed have trailer brakes?
Ashby
'00 Rodeo LSE 4WD, 3.2, Black, LSD, OME 919s w/ 2in Spacers, Superwinch Hubs, RS9KXLs, Indy4x steel braided brake lines, LT 265-75-16 MT/Rs, ShrockBars, DOR HD rear Lat. Bar, MagnaFlow.
Re: Towing with Trooper #128106 09/18/02 12:31 AM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by 4Play:
<strong>Did the flatbed have trailer brakes?
Ashby</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">I'm guessing it did if Mike didn't complain about braking issues, and that's the other thing... The braking system isn't really up to the task of towing that much weight if there are no trailer brakes. Towing with basically the same brake setup (Amigo vs. Trooper) and about 1000 lbs LESS meant a whole lot of brake fade without trailer brakes...
HTH,
Chris
Chris Perosi
OutdoorWire, Inc.
Re: Towing with Trooper #128107 09/18/02 01:29 AM
Harhir Offline
I have to agree to Chris. Be careful with a trailer without brakes. I have a pop-up trailer and completely loaded this thing weighs about 2000lbs. This rig has no brakes. It is a small trailer but I already got in the situation where I had to do an emergency stop. I was really glad that nobody was directly in front of me.
It was a shock for me because I was only used to trailers with excellent surge brakes. You did not even notice a diffence with the trailer because the brakes were so strong.
I would not recommend towing heavier trailer without brakes. Pulling is fine, but stopping ....
My next camping trailer will have brakes again, no matter how light it is .....
By the way in Germany the Trooper is rated from Isuzu to tow about 7700lbs (3.5t) with brakes on the trailer and about 1650lbs (0.75t) without brakes on the trailer.
Stefan
2001 Trooper
Re: Towing with Trooper #128108 09/18/02 02:43 AM
I don't think it's just Germany the troopper is rated to tow over 7k lbs , I think it's everywhere other than the U.S.A.
Chas
Re: Towing with Trooper #128109 09/18/02 09:56 AM
4
4Play Offline
Does the troop offer 4-wheel disc brakes on all their trim levels? I know for the Rodeo, in 2000 only the 4wd had the front and rear discs.
Ashby
Re: Towing with Trooper #128110 09/18/02 12:44 PM
Paisan Offline OP
All Isuzus have had 4-wheel disc brakes since at least 97.
Yes I only towed one trailer over 2000lbs once w/o brakes and never again will I do it, even though in NYS you can tow w/o brakes up to 3500lbs. The Uhaul did have brakes, and darn good ones too! I once dolly towed a SAAB and it was horrible trying to stop that thing!
I was just glad to help out DougH darn kids always getting into trouble! hee hee!
-mike
Re: Towing with Trooper #128111 09/18/02 01:53 PM
RobG Offline
<strong>I know for the Rodeo, in 2000 only the 4wd had the front and rear discs.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">My 1995.5 Rodeo has rear discs. All Rodeos with the rear D44s had discs (this means all 2nd gens and some 1st gens). 2nd gen Amigo's got rear discs. And i don't think Troopers picked up rear discs till their 3rd gen.
As for the uhaul flat bed, the one i rented to tow my broken Rodeo back from KY, it didn't have trailer brakes, only hydralic brake-away (not to be confused with hydralic surge brakes).
can an Isuzu tow 5000+ lbs? sure, i've done before as well with my Rodeo. Would i make a habit of doing so? Absolutely not. As chris mentioned, the transmission would be my biggest concern, not the engine. I know i've take a few years life off my clutch with some of the towing i've done. And not to mention the Trooper/Rodeo just doesn't have the shear weight of a fullsize truck for towing the heavy loads.
And as a side note, when towing any heavy load close to (in this case over) the towing capacity of Trooper, trailer brakes are definitely a necessity! 6600lbs is well over what the Trooper itself weighs, excepting it to stop with such a load in an emergency would be asking for a miracle.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 38x13 TSLs, spooled D60 front, 14bff rear locked by detriot, high steer w/ hydro, dual Isuzu tcases.
Re: Towing with Trooper #128112 09/18/02 02:27 PM
Mitsuzu Offline
<strong>All Isuzus have had 4-wheel disc brakes since at least 97.
-mike</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">2wd Amigos have drums in the rear, not sure of 2wd rodeos
Joe
Maybe for once, someone will call me 'sir' without adding 'You're making a scene'
PHP: 7.4.33 Page Time: 0.017s Queries: 15 (0.013s) Memory: 0.6392 MB (Peak: 0.7635 MB) Data Comp: Off Server Time: 2026-11-04 13:36:07 UTC
