Q: Edelbrock Intake Mainfold installed on a GM 60* V6? #129166 03/04/03 08:08 AM
MattGold Offline OP
I was wondering if anybody has ever installed one of these manifolds on a 2.8 or a 3.1 GM V6?
Edelbrock lists the intake as a 2-piece manifold with to options for carbs a 2-bbl or a 4-bbl. There is mention of a Holley Carb that fits?
My Q is that with a TBI do I have any options for this manifold? The only manifold that Edelbrock lists for a TBI is for the 4.3 90* V6.
Many thanks....
Matt
92' Rodeo with a lot of DOR parts
Re: Q: Edelbrock Intake Mainfold installed on a GM 60* V6? #129167 03/04/03 03:37 PM
Ed Mc Offline
There is a discussion ongoing at the S-series.org 60 deg V6 forum regarding this very subject:
http://forums.s-series.org/viewtopic.php?t=13925&sid=914eb7d45db5002d3ef64f098bd6693a
You could use a TBI-to-4bbl adapter atop the 4BBL manifold top, however you'd lose EGR. The 2-bbl manifold top retains EGR but you'd need a special-made adapter to mount the TBI.
The thing that gets me is the uneven runners from side to side. Without having the matching Edelbrock TES headers (the S-10 headers won't fit a Trooper), I can't see how uneven runners would benefit.
Personally, the stock TBI manifold, bored out, and maybe port-matched to the heads, probably flows as well or better than the funky Edelbrock. Maybe a little Extrude Honing to smooth out the runners?? It'd be interesting to see airflow 'stats for these intakes.
If I were going to look for a different intake, I think maybe an Offenhauser Dual-Port might be a good choice. Unfortunately they aren't made anymore so you'd have to find a used one somewhere. Saw one on eBay once but they are few and far between.
'90 Troop 3.4 LS
'89 Troop RS (Has Valve Issues, needs Counseling)
HI, I'm Ed and I'm a Trooper-holic!
Keep On Troopin'......
PHP: 7.4.33 Page Time: 0.009s Queries: 14 (0.006s) Memory: 0.5871 MB (Peak: 0.6351 MB) Data Comp: Off Server Time: 2026-10-21 19:33:19 UTC
