5.38 install kit? #138424 12/06/02 12:24 AM
Roadends Offline OP
THE gears are here! <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
I recall small discussions and comments being made throught the 5.38 group buy process regarding installation kits for these.
I did the search in Talk and Tech and couldn't find specific answers.
Are there installation kits available? Are the 5.38's dimensions compatabile with stock 4.56 and a kit for that set can be used? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
I started calling around for price quotes (WOW! guess I'll be pulling the 3rd members myself. What a big difference in price!)
Some of the q's the shops asked was about the install kit. My concern is how readily available are they?
Some of the shops frowned or didn't accept the job because I had my own gears. One shop said he could have probably gotten them cheaper... right, OK thank you, Bye. <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Another shop had a concern about the carrier... if Tera had compendsated for the size... <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
But anyway, I'm babbling. <img border="0" alt="[Ignore]" title="" src="graemlins/ignore.gif" /> Has anyone else started with their 5.38 install? any problems? where to get the installation kit?
These are going in my '90 pick up. anyone with a similiar set up doing the 5.38 themselves? problems?
I'm egar to get this done. I want to be able to have all the "parts and accecories" available to drop off on their desk and say "please do for me".
Thanks much
<small>[ December 05, 2002, 06:26 PM: Message edited by: zuzusan ]</small>
Kim
'99 2wd Rodeo LS, '90 4x4 Isuzu Pick up
Re: 5.38 install kit? #138425 12/06/02 12:37 AM
RobG Offline
<strong>Are there installation kits available? Are the 5.38's dimensions compatabile with stock 4.56 and a kit for that set can be used? </strong>
Well, an install kit consists of pinion shims, carrier shims, crush sleeve/pinion preload shims, marking compound, pinion nut and sometimes new bearings/ring gear bolts. None of this stuff should be effected by the Tera 5.38s as where all these pieces ride is unaltered... so yes, a 4.56 install kit would work just fine, in fact, any install kit for an Isuzu 10-bolt (someone correct me if i'm wrong here).
<strong>Another shop had a concern about the carrier... if Tera had compendsated for the size... <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong>
yes, the stock carrier is what these gears were designed to fit.
Good luck with the install. Make sure to report back to us <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
-Rob
<small>[ December 05, 2002, 06:37 PM: Message edited by: RobG ]</small>
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 38x13 TSLs, spooled D60 front, 14bff rear locked by detriot, high steer w/ hydro, dual Isuzu tcases.
Re: 5.38 install kit? #138426 12/07/02 10:15 AM
Roadends Offline OP
OK Rob, thanks.
I'm gonna put the truck on jack stands tomorrow and break open the Haynes.
I'll start with the front since thats supposed to be the toughest end then go to the rear.
A good winter project so I have plenty of time.
The wife just bought a digital camera I need to learn to use, then I'll take a few pic's
Kim
PHP: 7.4.33 Page Time: 0.011s Queries: 14 (0.007s) Memory: 0.5965 MB (Peak: 0.6525 MB) Data Comp: Off Server Time: 2026-11-16 08:39:35 UTC
