87' Auto Trans Line Leak #167916 09/10/02 03:54 PM
mustangjs Offline OP
Any suggestions on fixing a automatic's Tranny Cooling Line Leak...
The flare fitting joining the Tranny cooling line to the Transmission ( the one with some type of sensor attached) is leaking. It was still tight... I guess the flare must have worn due to vibrations?? It appears in good condition.
I will cut out the bad flare out and reflare the existing tube. I just hope I have enough room.
Anyone have experience with this?
This is the first time I have ever seen such a connection fail. Broken lines Yes, Leaking flare connections No.
or should I just Replace Both Lines to be safe... ~130,000 mi.
2000 WJ Stock
Re: 87' Auto Trans Line Leak #167917 09/11/02 12:17 AM
Replace both lines. Check the old lines where they run through the brackets. They may be thin there also. Check the tranny mount and both engine mounts. I am in the middle of a new engine and tranny project. I found that 75% of my tranny mount has delaminated from the metal plate and I pulled my engine out without unbolting the mounts, they were that bad. Good Luck.
Re: 87' Auto Trans Line Leak #167918 09/12/02 01:54 PM
You should be able to generate enough slack by a little judicial bending of the tube and brackets. Be wary of the tranny temp sensor you are hooking up to, as the body is soft stuff. Now would be a great time to hook in a true tranny temp gauge.
Re: 87' Auto Trans Line Leak #167919 09/12/02 10:11 PM
Mine just started leaking, too.
Where can one buy these lines? are they avail online somewhere?
PHP: 7.4.33 Page Time: 0.007s Queries: 14 (0.004s) Memory: 0.5970 MB (Peak: 0.6563 MB) Data Comp: Off Server Time: 2026-06-09 21:35:58 UTC
