Trailer hitch
#180768
07/12/02 06:22 AM
On my 2000 Montero I want to install my Yakima (Hitch mount) bike rack, but all I have is the tow loop. I was going to purchase the U-Haul hitch but it looks like it mounts too low, (less departure angle). Is there any brand that mounts onto (in place of) the tow loop? I need a square reciever for the bike rack. It will actually tow a trailer in the near future. Thanks in advance!
2000 Montero, ARB bumper, TJM snorkle, OME suspension, Maggiolina Extreme RTT, BFG KM2's 33/10.5/15. ARB fr/rear lockers, 3.15 transfer case.
Re: Trailer hitch
#180769
07/12/02 06:31 AM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by RogerH: <strong>On my 2000 Montero I want to install my Yakima (Hitch mount) bike rack, but all I have is the tow loop. I was going to purchase the U-Haul hitch but it looks like it mounts too low, (less departure angle). Is there any brand that mounts onto (in place of) the tow loop? I need a square reciever for the bike rack. It will actually tow a trailer in the near future. Thanks in advance!</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">A better alternative is the kind of rack that mounts via a plate behind your spare tire. This rack hard mounts to the spare so you don't have excessive movement like you would get with a hitch rack. <img src="http://www.sportsrack.com/catalog/BVG0093_lg.jpg" alt="" /> And since it's so high up, you don't need to worry about any real clearance issues unless your doing some major ledges or ascents/decents. Best of all, it's only $149!! http://www.sportsrack.com/Detail.bo...n=AND&start=1&total=4&no=631 <small>[ 12 July 2002, 01:32 AM: Message edited by: off-roader ]</small>
Re: Trailer hitch
#180770
07/12/02 06:40 AM
Thanks! I already own the Yakima and had it on my Land Rover and with a few shims it never moved. Since I already own it...I would like to try to use it. Also, my bike is a full suspension so the hitch mount I have allows me to carry the bike with its funky geometry. Thanks though...I will keep this one in mind.
Re: Trailer hitch
#180771
07/12/02 07:18 AM
i heard a Hidden Hitch is a good hitch for cheaper than Uhaul. Better design, stronger, and better departure angle. try this thread from Isuzu board Hitch Thread
Christian 88' Runner, SAS, Dual Cases, 529's, Locked, 37" MTR's, TR Beadlocks, blah blah.
Re: Trailer hitch
#180772
07/12/02 07:23 AM
RogerH, This is what I put on my '95. 2" reciever. It hangs down a little. Not too much though. http://www.zhub.com/ozarktruckoutfitters/listings/22.html It says the hitch is for 92-98 but if the bolt pattern is the same it should fit just fine. You can see a picture of what it looks like on my rig on my web page. Trailer hitch Hope this helps? Do you have the tow loop that bolts on to the center of the frame? Want to sell it to me? -Kirk
'96 SR, 35's, body lift, arb front bumper, Custom rear rock bumper, rock sliders. '89 Raider V6 w/ SR rear axle & locker Kirk's Montero page but not updated in forever KJ6GVJ
Re: Trailer hitch
#180773
07/12/02 01:38 PM
I am also using the Sure Pull hitch that Kirk is recommending, and I give it a thumbs up. One of the things I like about it is that it is very easy to install and remove.
'89 LWB, V6, Auto, 31" BFG AT, ARB Locker, ARB Bumper, Aisin Manual Hubs, Dual Bouncy Seats
Re: Trailer hitch
#180774
07/12/02 03:26 PM
I don't know about your truck, but I know John Baker sells a receiver hitch for Monteros that mounts to the frame plate on many monteros so you don't have that huge hitch mass under the bumper killing your departure angle.
Re: Trailer hitch
#180775
07/13/02 05:25 AM
Try this out... <img src="http://www.zhub.com/ozarktruckoutfitters/listings/22.jpg" alt="" /> http://www.zhub.com/ozarktruckoutfitters/listings/22.htmlThis drops down but you could probably have a similar one made but with less drop. Just have a local fabricator make one since your only using it for your bike rack. It should be pretty easy... 2x2 tube steel and 3/8" plate steel. FWIW, I too own a dual suspension bike (GT Team RTX & XRC-1) but they both have a top tube that I can clamp on with my rack. Both Yakima and Thule make top tube adapters for bikes w/out top tubes. <small>[ 12 July 2002, 12:30 PM: Message edited by: off-roader ]</small>
Re: Trailer hitch
#180776
07/13/02 12:08 AM
Many thanks to all! This is exactly what I was looking for.
Re: Trailer hitch
#180777
07/13/02 12:15 AM
You can always take it off like I do, takes 10 mins.
Rodney,95 SR 3.5 L, Rancho RS 9000's, 31x10.5-15 Bridgestone Dueler A/T's, OEM Rear locker My Monty in action!
