Page 11 of 14 1 2 9 10 11 12 13 14
Re: Specialized Part Number Repository #196295 12/07/05 03:28 AM
DaphneD Offline
[color:"red"]Mitsubishi[/color] Torque Converter Bolts
There is an aftermarket warning out concerning these bolts which states that old torque converter bolts stretch over time which can damage the torque converter housing and internals if reused. In order to prevent this it is recommended that you should either 1) grind down the old bolts by a millimeter or two, or 2) purchase new bolts to use when installing your torque converter.
Though the warning concerns primarily lockup converters used in many (if not all) '91 and later Monteros, I believe I may have some experience with this problem with my old non-lockup torque converter. Having knowledge of the issue I decided it was easiest to purchase new bolts and I would urge you to do the same if you or your mechanic are performing work which will seperate the torque converter from the driveplate.
(6) MD950120* - Bolt, Transmission Connecting
*The part number may be different between model years but I'm 99% certain it is the same bolt. Also the bolt is standard not metric thread.
Re: Specialized Part Number Repository [Re: DaphneD] #196296 12/07/05 03:31 AM
87Montero Offline
Edit: That part number is for one bolt.
Re: Specialized Part Number Repository *DELETED* [Re: 87Montero] #196297 12/07/05 05:18 AM
FrankR Offline
Post deleted by FrankR
Re: Specialized Part Number Repository [Re: 87Montero] #196298 01/13/06 05:03 AM
photoduo Offline
Sliding Rear Side Window Latches...
Montero and Raider 1983-1991
PN# MB134115
$7.36 each from
http://www.parts.com/partlocator/index.cfm?siteid=214144
<img src="/forums/images/graemlins/smile.gif" alt="" />
Astoria, Oregon Coast
1987 Dodge Raider
Re: Specialized Part Number Repository [Re: photoduo] #196299 03/31/06 09:23 PM
Gen I hazard light switch: MB330277
SWB weatherstrip, exterior, the one that likes to fly off when driving down the freeway: MB364413 (driver's side).
Re: Specialized Part Number Repository [Re: Grandpa Bill] #196300 07/06/06 03:31 AM
CerOf Offline
US Spec 3.0L Montero Sport w/ Auto Transmission
Transfer Case part numbers:
MR453346 : GEAR,T/F INPUT
MB896674 : GEAR,T/F LOW SPEED
MB896675 : GEAR,T/F COUNTERSHAFT
Re: Specialized Part Number Repository [Re: CerOf] #196301 08/15/06 02:23 AM
rrodriguez Offline
1989 Dodge Raider L4 2.6 Carb. Man W/Rear leaf springs
Autolite Pro-Fit silicone spark plug wires 86606
MSD Ignition 8.5 mm Super conductor wires PN 31659
Micron distributor cap BD556 WA479R
Micron Rotor WA331 BR503
Napa Premium XL Alternator/Water pump belt 9380
Gates Power Steering belt XL 9295
Micron Fuel filter GF61M G12 F20011M
K&N high flow air filter E-2723
Purolator air filter A34494
Bosch Premium oil filter 3320
PDQ U-Joint rear driveshaft 1-1516
Carquest lower ball joint K9009
Explorer ProComp ES3000 Shock front 314515
Explorer ProComp ES3000 Shock rear 319500
Re: Specialized Part Number Repository Master cylinder [Re: rrodriguez] #196302 08/26/06 04:54 AM
Kevin C Offline
Part # Description QTY Price
A1C132464 13-2464/MC39972 NEW MSTR CYL 1 $63.99
Rockauto, Cardone select master cylinder. This is a reboxed, japanese made, brand new NABCO part that is the same as part the factory sells. Basicly its a complete new unit for less money than the factory rebuild kit.
Fits 1990 Montero.
Kevin
Re: Specialized Part Number Repository Master cylinder [Re: Kevin C] #196303 02/07/07 03:58 PM
powerRam50 Offline
i copyed this from mister bishi's post for 5.29 gears,it sounds perfect for being in here.
Hey guys I have been bombarded with enquiries about these lately and I just can't keep up.
I've spoken to the supplier and he has agreed to deal directly with individual customers as I just haven't got the time anymore to expadite these purchases.
The company is WADC (West Australian Drive Components) http://www.wadc.com.au/
Contact is Vincent Gallucio vincent@wadc.com.au
His email as follows with prices :-
Dear Frank,
Pricing as follows.
MB241981 front 8ö CW&P = $540.00 Aus + tax (10%)
MB598486 rear 9ö CW&P = $640.00 Aus + tax (10%)
The above price does not include freight to Victoria.
Delivery time approximately 2 months from order confirmation.
It is possible to air freight the goods from Japan to US if you need them urgently. (additional cost)
Payment terms are the same as your previous order with 85% of the invoice total payable at the time of order confirmation, with the balance due at delivery into Australia.
Kind Regards
Vincent Galluccio
(WA Drive Components)
PS - I'm still happy to advise of the correct part number of 5.29 to make sure it's the right one.
Please bear in mind the Vincent doesn't know anything about what 5.29 fits what model he will only be able to quote on supply of a given part no.
Cheers, Frank.
Part no's are :-
4 cylinder (all)
front 7.25" MB185457, rear 8" MB241981
Gen 1 3.0 V6 (all)
front 8" MB241981, rear 9" MB598486
Gen 2 3.0 V6 (auto only)
front 7.25" MB831032, rear 9" MB598486
Re: Specialized Part Number Repository [Re: MarkG] #196304 02/20/07 12:46 AM
CapnCrunch Offline
Part numbers for the Aisin hubs.
Front Hub Handle Seal: Toyota 43532-60010
This is the O-ring that seals between the dial indicator and the hub cover.
Front Hub Cover Gasket: Toyota 43531-60010
This is the gasket that seals between the hub cover and the hub body.
Front hub cover bolts:
Mitsubishi MB160712
Toyota 91641-80616 (Same as Mitsu bolts, cost less)
These are the bolts that hold the hub cover to the hub body.
Thanks to DougB for the updated Toyota part numbers
Additionally, the inner gasket (the one which sits between the hublock assembly and the wheel hub) is Toyota part number 43422-60010. If you go to a Toyota parts department, let them know that all of these parts are found on Aisin manual locking hubs which came on 83-89 Toyota pickups. All these seals fit the Mitsubishi Aisin manual hubs perfectly.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.007s) Memory: 0.6554 MB (Peak: 0.7822 MB) Data Comp: Off Server Time: 2026-06-20 20:22:36 UTC
