Page 13 of 14 1 2 11 12 13 14
Re: Specialized Part Number Repository [Re: hazy_daze] #196315 04/08/09 03:00 PM
sidecardog Offline
Hi guys,
Anyone have the part number for the Fuel Filler Hose on the Gen I 3.0?
Thanks
Matt
2002 Montego Limited, 3.5 V6, 90K, just purchased
1990 Montero LS, LWB, AUTO, 3.0 V6, 250K, 2" SL, 31" tires--SOLD
1959 Vespa VBA150 all original w/sidecar
Re: Specialized Part Number Repository [Re: sidecardog] #196316 04/08/09 03:30 PM
Happy Birthday hazy_daze Offline
Hi guys,
Thanks
Matt
MB554777
head light for a 1991 pajero [Re: sidecardog] #196317 04/13/09 12:03 AM
Scott75 Offline
hi guys , if anyone out there knows a part # for a 91 pajero head light can you please let me know . thank you very much
Re: Specialized Part Number Repository #196318 08/01/09 12:08 AM
Replacement bulb for Gen II digital compass.
Mitsu p/n: MR283314
Manufacturer: Mitsu (I have not found a 3rd party manufacturer/source such as Sylvania/Osram or RadioShack.
Source: Your local OEM Mitsu Parts dealer
Cost: $2.50 as of 31, July 2009 at Stevens Creek Mitsubishi, San Jose, California
Will post pics this evening once I get home. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Gen 1 Heater fan resistor and switch. [Re: off-roader] #196319 08/29/09 08:47 PM
TrailRaider Offline
Gen 1 Heater fan resistor.
MB272517 was about 30 dollars when I bought one about a year ago.
Bought a new switch at the same time also from the dealer, when I find that number i'll post it up as well.
*edit*
Could we get this stickied to keep it up top? Mabey it will help reduce the number of "what is this part number" question <img src="/forums/images/graemlins/smile.gif" alt="" />
'89 Raider V6 auto.
Re: Gen 1 Heater fan resistor and switch. [Re: TrailRaider] #196320 08/30/09 01:43 AM
Grasscat Offline
*edit*
It is sticky, check the very first post on this page.
Michael j
TreadLightly! Trainer
Re: Gen 1 Heater fan resistor and switch. [Re: Grasscat] #196321 11/13/09 05:51 PM
Longer upper radiator hose for GenI with body lift.
NAPA P/N 8637 ~$20 retail as of 11/13/09.
Re: Gen 1 Heater fan resistor and switch. [Re: hazy_daze] #196322 11/13/09 11:01 PM
95-96 3.0 24V SOHC timing pulleys need to be ordered aftermarket as 3.5 DOHC.
For Gen II 3.0 24V SOHC motors, there is mixed/wrong data out in the aftermarket. With my 95's 180k service, I ordered a pulley kit for the timing belt change from the local store. The kit only comprised a tensioner puller, and it was the wrong one. This was a Dayco product and looking at other places online brought up the same number.
Wondering what was up I launched CAPS and compared the Mitsu numbers between the three motors- 3.0 24V SOHC, 3.5 DOHC, and 3.0 12V. My 3.0 24V SOHC needs the same pulleys as the 3.5 DOHC. What I got was for the 3.0 12V.
Not sure what other parts may be similarly afflicted. I do know that when ordering other such parts in the future, I will be sure to cross reference between the three motors.
Re: Specialized Part Number Repository #196323 03/04/10 04:12 AM
Electronic compass light bulb for '95 SR/Gen 2
MB898179
Bulb, Console
Mitsubishi dealer part
Twist the light bulb's base counter-clockwise to remove after removing center guage cluster hood, removing cluster from dash, removing screws that hold cluster's plastic screen and removing wiring harness hold-down screws.
Bulb is specialty because of its base and because it has a plastic cap over it to alter the output color.
Cost should be around $2. Compass is not visible in daylight or at night if the bulb is burned out. Compass has to be recalibrated after reinstallation. Consult owner's manual.
Re: Specialized Part Number Repository [Re: JohnnyBfromPeoria] #196324 05/18/10 03:31 AM
TrailRaider Offline
KM132I, KM123K, KM145 manual trans 1970-89 gasket set.
Felpro # TS80310-1 $21.00 from my local Kragen store.
Includes multiple gaskets for the various trans models.
'89 Raider V6 auto.
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.007s) Memory: 0.6504 MB (Peak: 0.7756 MB) Data Comp: Off Server Time: 2026-06-23 13:04:24 UTC
