Page 4 of 5 1 2 3 4 5
Re: Whoa! Steering hops in 4x4 !?!? What gives?? #12431 07/28/03 11:10 PM
elripster Offline
So have you made absolutely sure that front diff, which you said had been apart, is the same ratio as the rear? You problem sure sounds like a missmatched gearing issue.
Just curious, is this accompanied by any odd sounds, metallic or otherwise?
Frank.
1994 4runner, 3.0, auto, 4.88's, 31's, BJ spacers, Coil spacers, air shocks, D-ring anchors, 4Crawler F/R swaybar discos.
www.sdori.com
Re: Whoa! Steering hops in 4x4 !?!? What gives?? [Re: elripster] #12432 07/29/03 02:45 PM
Only sounds are some rumbling while moving, and the tires chirping to release tension. The drivetrain itself is kinda noisy as mentioned before but I don't think that has anything to do with it. I still need to confirm the gear ratios but have other fish to fry at the moment.
Grease used was very light, looks like whipped margarine.
Re: Whoa! Steering hops in 4x4 !?!? What gives?? #12433 07/29/03 05:43 PM
elripster Offline
Cool. I'm almost positive you have mismatched gears. There is no other way for your tires to build that kind of tension. I mean if one was binding say, your steering wheel wouldn't hop, it would pull to one side with tremendous force. They simply have to be either pulled or pushed faster than they are turning but consistently as to get the front end ocsillating or hopping.
Frank.
www.sdori.com
Re: Whoa! Steering hops in 4x4 !?!? What gives?? #12434 08/03/03 04:56 PM
L
liam_the_red Offline
Probably in the front driveline/yoke/u-joints. I run into this all the time in the shop. Once-in-a-while-wheelers don't get the front joints lubed. They wear a little funny. Jack up the front and then check the front u-joint at the pumpkin. I'll bet its bad. It will feel OK unless you jack it up to test.
Tony
Owner - Maintenance Plus - (4X4 and offroad Mechanic)
80 Toy - disassembled for refitting. '78 CJ-5 still alive. 74 GMC 1-ton full time 4X4,454, B&M TH350,Detroit lockers.
Re: Whoa! Steering hops in 4x4 !?!? What gives?? [Re: liam_the_red] #12435 08/03/03 05:32 PM
Aha, a new idea, will check that out. Another thing to keep in mind is that I am almost positive my truck has never been offroaded. Front suspension and ball joints have no play, no scrapes on the bottom anywhere. And I have only used 4x4 rarely because of this issue, usually pretty tame stuff; gravel, snow, etc.
Re: Whoa! Steering hops in 4x4 !?!? What gives?? #12436 10/31/03 10:04 PM
shawn p Offline
Ok so the update is the front end had different gears than the front? Thats horrable!
2006 tacoma
SR5
4x4
V6 Auto
Re: Whoa! Steering hops in 4x4 !?!? What gives?? [Re: shawn p] #12437 11/02/03 02:46 AM
Maybe. The two operative theories at the moment are mismatched front diff or bad U joint behind it. The diff itself is in perfect shape, maybe out of an automatic, which came with stock 1:4.3 not 4.1
http://www.va4roc.com/archive.htm#reference
Re: Whoa! Steering hops in 4x4 !?!? What gives?? #12438 11/05/03 06:46 PM
Once again Roger has exactly the reference needed on his web page. Now I just gotta hope the "pinion flange shaft" is easily visible and still has the color code on it...
If it turns out one is a 4.3 I may just swap the other to 4.3 instead of both to 4.1. Minor difference but might as well. This would also be the time to get a 4.3 LSD if the rear is 4.1, hmmmm...
Re: Whoa! Steering hops in 4x4 !?!? What gives?? #12439 11/06/03 06:15 AM
i had one of these do the same thing. jack passenger front wheel off ground leave the others on ground. try to turn the pass wheel back and forth by hand while watching your steering arms. especially your pitman and idler arms. my idler was worn and letting the steering arms move up and down. this is very common with the ifs front. it would pull one wheel in, then the other when its locked in 4x4. that is the open diff switching back and forth. when its in 2wd there is nothing pulling on the front wheels to make them go L to R. have someone stand in front while you drive toward them to see what its doing.
if it is different gears front and rear. you should hear and see some serious tire slipping, just when idling around. for your sake i hope its just the idler arm. its much easier to fix.
Re: Whoa! Steering hops in 4x4 !?!? What gives?? #12440 11/06/03 06:45 AM
ok man i'm about 99.99 percent sure you have missmatched gears. my bro bought his truck about 3 months ago with the same problem. you can either do it yourself or take it in to a gear shop to check. we just put his up on blocks and counted rotations.
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6287 MB (Peak: 0.7509 MB) Data Comp: Off Server Time: 2026-10-24 12:56:35 UTC
