Gear Oil #199707 02/19/03 11:22 PM
kiks Offline OP
I have a 1994 Montero SR, V6,3.5, DOHC, with Rear Differential Lock.
I am not certain if ,my rear differential is LSD or not. Is it okay to use LSD gear oil on a non-LSD differential? Will there be some risk/damage?Thanks in advance.
Frank
Montero SR, 3.5 , 1995 model, ABS, Rear Differential Lock
Re: Gear Oil #199708 02/19/03 11:29 PM
DougH Offline
Mitsubishi Forum Moderator
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by kiks:
<strong>I have a 1994 Montero SR, V6,3.5, DOHC, with Rear Differential Lock.
Frank</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">It is fine to use LSD compatible gear oil in a regular differential (open). The lsd additive in the oil makes the lsd behave much better on the street, but it wont effect a non lsd diff. On the other hand if you do have an lsd you dont want to run plain gear oil on the street.
DougH
1995 SR - RIP
1993 RS - RIP
Re: Gear Oil #199709 02/20/03 01:50 PM
kiks Offline OP
Thanks, DougH
Re: Gear Oil #199710 02/20/03 05:55 PM
Jay Ayala Offline
kiks, I recenly posted about changing the Rear LSD fluids. I have a 1989 Dodge Raider with Rear LSD. It's probably a little different then what you have equiped on your 1994 Montero but the principal is the same.
Check out my thread: 3.0 Raider - LSD oil change (pics)
You just might find some helpful information.
Re: Gear Oil #199711 02/20/03 09:35 PM
kiks Offline OP
Thanks Jay
Re: Gear Oil #199712 02/21/03 05:28 AM
Grandpa Bill Offline
Jay, why the 85W-140? My 89 manual says to use 80W-90. Not to argue with your logic, I'd like to know how it's working out. I'm a firm believer in heavier oil, up to a point. Since I'm going to change the oil in both diffs and the T/C I'd like to get your feedbback on this one before I do it.
Bill Mattson, Certified Old Guy
Monty-less (right now)
Laura Mattson, Certifiable
Get in, sit down, BUCKLE UP, shut up and HANG ON!!!
Re: Gear Oil #199713 02/22/03 06:56 AM
Jay Ayala Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Grandpa Bill:
<strong>Since I'm going to change the oil in both diffs and the T/C I'd like to get your feedbback on this one before I do it.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">I too read that the factory manual said 80W-90. I can't exactly recall the reason I went and purchased the heavier weight. I think it had to do with the temperature climate here in Western Oregon. But I made that desicion a while back ago. Anyway to answer your question about how it is working, around town it has worked great. Better then great acutally, it relieved the shaking and the vibrations that was felt through the driveline. Now its quite and there is absolutely no noise or vibrations coming through the drive line. I'm pretty sure that the old differential fluid didn't have the friction modifier in it, and that is probably why the differential was making noise and vibrating in the first place. But it works great now, really smooth. I'm so impressed. I can't say enough about it. So far, besides finding the pen blocking my defrosting vent, this has been the one modification or part of the maintenance that has had the best results. They were instant. As soon as I put it in I felt a really big difference. I can't believe all of the little things I've done to it to make it run better. It is almost a whole new truck from when I purchased it last October.
This weekend is the real test, tonight I will be driving my Raider with the new fluid in it for 4 hours non stop to get to eastern Washington state. Then on Sunday I will be driving back agian 4 hours non stop. So I'll have a better report for you on Monday. I'll post the results on the other thread: 3.0 Raider - LSD oil change (pics)
Suprisingly, there has been a lot of people on the message board doing the diff fluid lately. So, I'm sure a lot of you who have read these similar posts here on this message board will realize that I've been linking to my thread every chance I get. I just can't say enough about how well it has worked for me.
Like I said, so far - 1 weeks worth of city driving it has been really great! I will post on Monday about the performance on the 500 mile round trip I will be taking this weekend in the other thread.
Jay
Re: Gear Oil #199714 02/21/03 07:04 PM
Augie Offline
<strong>Since I'm going to change the oil in both diffs and the T/C I'd like to get your feedbback on this one before I do it.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Not sure about gen 1 T/C. It might not have the syncroniser and it might be OK to use GL5 differential oil in it, But if its gen 2 that have shift on the fly you would need GL4 or it would not fuction properly.
Re: Gear Oil #199715 02/21/03 11:34 PM
pmontero Offline
Don't use anything but GL-4 in a Gen I transfer case! This has been batted around and I have read through all of the threads on this...
For Gen I users, here is a great gear oil for front diff, transfer case and rear open diffs. It is for services GL-3, GL-4, GL-5.
<img src="http://pics.montypics.com/pmontero/2003-02-21/napago_1-032041.jpg" alt=" - " />
If you have an LSD rear diff, use this combo. One additive bottle first and fill it the rest of the way with gear oil.
<img src="http://pics.montypics.com/pmontero/2003-02-21/napago_2.jpg" alt=" - " />
If you don't ride your horse in the creek often, you might want to go with synthetic oil. Here is what I would put in front and rear open diffs.
<img src="http://pics.montypics.com/pmontero/2003-02-21/napago_4.jpg" alt=" - " />
Here is what I would put in rear LSD diff.
<img src="http://pics.montypics.com/pmontero/2003-02-21/napago_3.jpg" alt=" - " />
Here is what I would put in the transfer case.
<img src="http://pics.montypics.com/pmontero/2003-02-21/napago_5.jpg" alt=" - " />
If you like to get your Monty wet a lot, don't go with the synthetics... you'll be blowing a wad if you do since you should replace these fluids and tranny fluid after any deep fording. You should also grease, grease, GREASE the zerks as well.
If you have a wad to blow, you should be buying a Don's bumper, Don's *NEW* ezfit rocker skids and a safari snorkel!! <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
Powell
P.S. - I love NAPA!
'87 Montero Diesel
'98 Porsche Boxster Electric
and more...
Greasology
NotPetroleum
Re: Gear Oil #199716 02/24/03 03:15 AM
pmontero Offline
ARCHIVE This question is coming up a lot lately...
Powell
'87 Montero Diesel
and more...
Greasology
NotPetroleum
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6435 MB (Peak: 0.7669 MB) Data Comp: Off Server Time: 2026-06-22 07:27:57 UTC
