IDLING - Rythmic Up And Down #202026 03/12/03 01:06 AM
kiks Offline OP
My idling would fluctuate by about 150RPM up and down. The IAC(Servo) is new, 2 months, from a Mits. dealer in LA.
This came around just one morning.
Please tell me where to start looking for the cause.
Thanks.
Kiks
Montero SR, 3.5 , 1995 model, ABS, Rear Differential Lock
Re: IDLING - Rythmic Up And Down #202027 03/12/03 01:13 AM
Check the IAC again, constant flux would indicate IAC, check the o ring and all atachments....
Re: IDLING - Rythmic Up And Down #202028 03/12/03 01:20 AM
PHIL_ Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by kiks:
<strong>My idling would fluctuate by about 150RPM up and down. The IAC(Servo) is new, 2 months, from a Mits. dealer in LA.
Thanks.
Kiks</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Also, check for carbon buildup in the throttle body.
We have an article here on the wire: Tech: Solving the 3.0l V6 Idle Problem
Something to check anyways...
PHIL
Re: IDLING - Rythmic Up And Down #202029 03/12/03 04:48 AM
Geophie Offline
IAC, vacuum leak, fuel pump, ECU frying....ask mak013, he'll tell ya.
1991 4dr RS, ATK 3.0, auto. Now with zero trans fats!
Re: IDLING - Rythmic Up And Down #202030 03/12/03 04:22 PM
kiks Offline OP
I wiped the pintle of the IAC with a rag moist with Carburator Cleaner. Is it okay to wipe the end(pintle) of the IAC with engine oil?
Thanks again.
kiks
Re: IDLING - Rythmic Up And Down #202031 03/13/03 06:28 AM
TPS, maybe?
Re: IDLING - Rythmic Up And Down #202032 03/12/03 10:06 PM
http://pics.montypics.com/Jeepir/2003-03-12/idle_prob3.jpg
I think there is some other with some idle problems, so you are not alone. I`m not that into those and that question, but it could be that you have some problems with your TPS: Throttle position switch. it could be that you have some dirt or bugs where the air are suppose to float, but the MPS motor "07703", this thing is possible to replace, but those at my workshop told me that they have tried that a few times, but with no luck, so they somehow replaced the whole thing, but ofcourse there could be some other problem that is bugging you. But this was somehow just a tip..
<img src="http://picsmontypics.com/Jeepir/2003-03-12/idle-prob3.jpg" alt=" - " />
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.003s) Memory: 0.6104 MB (Peak: 0.6870 MB) Data Comp: Off Server Time: 2026-06-21 02:41:08 UTC
