CV joints and max tire size #213384 07/02/03 05:48 AM
tkal Offline OP
How big a of a tire would you say is safe to put on the 2.6 CV joints? I am not worried about the back, solid axel.
I was thinking of 33s or 35s. Both would require some wheel well remodeling. <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
'88 D-50 2.6 needs some love.
Re: CV joints and max tire size #213385 07/02/03 06:40 AM
Big Blue Offline
Just like most things, it depends on your driving style, and the terrian that you drive. Many of us run 33's. Lloyd is the only one that runs 35's and is having problems, but that may, or may not be related to the height of the tires.
There are others running 35's that are not having problems, so it could be terrian related or other. I don't see the added 1" of height to really be worth switching to 35's considering the added rotational mass when braking and the added unsprung weight while highway driving. all depends on what you want to do, and where you want to do it.
It's not about saying "I run 35's"
Kary
1987 Mitsubishi Pajero "Modified"
The other original Mitsu brother
Northwest Trailmaster
Re: CV joints and max tire size #213386 07/02/03 08:27 AM
Mister Bishi Offline
Hmmm over here there are quite a few guys with V6's running 35"s even with front lockers with little trouble maybe the odd CV and tie rod.
I personally wouldn't run bigger than 33"s on a 2.6 as the CV's are smaller (spline and axle diameter are the same though). I know a guy with a Gen 1 2.6 (front Detroit locker) who was busting CV's all the time until he upgraded to the V6 ones and only busts them now and then. But it's more driving style with him.
I believe there is a big difference between 33"s and 35"s, that extra 1" under the pumpkin translates to a lot offroad. Time and again I go wheelin with 35" rigs and I'm the one scraping the rear pumpkin with 33"s having a hard time where they have the extra clearance. Thats why I'm upgrading to 35"s after the body lift.
I just luv my "clacker Jabber".................
Re: CV joints and max tire size #213387 07/02/03 02:24 PM
I run with 35" 12,5 on a 10x15 -44 rim, but because of the modyfication before the bodylift-kit I have spacer`s on the rear axel, so I do not have that flex.. But my rig is modyfied more to run on snow than rocky and muddy surfaces, so I guess that 33" 12,5 would be a perfect over all option.. <img border="0" title="" alt="[Smile]" src="images/icons/smile.gif" />
<img src="http://pics.montypics.com/Jeepir/2003-06-21/1056242609_New_pick1_B_W.jpg" alt=" - " />
While sitting here writeing this few lines down, I have had no problem`s with my axel`s, even I have had some rather rough off road`ing, but I feel and belive that speed is the most common reason of damage, so I like thing`s slow and with 4x4 low while off roading.. <img border="0" title="" alt="[Smile]" src="images/icons/smile.gif" />
Re: CV joints and max tire size #213388 07/02/03 03:36 PM
Any brand/model preferences on the 33s? I have been very pleased with my Mich LTX M/S (as I have all Mich tires I've had in the past), especially in the snow during ski season. Michelin only goes to 32x11.50 for the A/T.
As my truck is also my daily driver at this point, though my daily miles aren't that great during the work week. So my interest in 33s is as much for "safety clearance" over non-hardcore routes.
Lastly, what about 33x12.50 on stock rims? I've seen that others have put 32x11.50 on.
Re: CV joints and max tire size #213389 07/02/03 04:03 PM
Selimyar Offline
i run 33x12.50 Super Swamper TSL bias ply on 10" wheels and have only trashed one cv axle in the past several months of hard wheeling, but keep in mind i trashed that cv at the same time i trashed my t-case and a rear u-joint due to some serious wheel spin on a uphill climb/bounce/landing/ouch!
recently i cranked my torsion bars down enough to lower my front end an inch, which helps with the cv axle angle ... this was possible due to the change in suspension geometry when i had my rear leaf spring over done, which actually raised the front an inch ... now my torsion bars are not at max crank, which is good ... i also went back to using high-profile lower bump stops up front because the 33s were rubbing up in the wheel wells too much
<small>[ July 02, 2003, 11:05 AM: Message edited by: Selimyar ]</small>
had an '88 Montero, then an '04 Rubicon ... sold 'em tho
Re: CV joints and max tire size #213390 07/02/03 04:21 PM
PHIL_ Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Selimyar:
<strong>recently i cranked my torsion bars down enough to lower my front end an inch, which helps with the cv axle angle ... this was possible due to the change in suspension geometry when i had my rear leaf spring over done, which actually raised the front an inch ... now my torsion bars are not at max crank, which is good ... i also went back to using high-profile lower bump stops up front because the 33s were rubbing up in the wheel wells too much</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">That's funny Ray. I just lowered my t-bars an inch the other day too. The a-arms were always bottoming out, and the ride was way too hard. How much did you gain in the front by lifting the back?
PHIL
Re: CV joints and max tire size #213391 07/02/03 04:38 PM
Selimyar Offline
Phil,
i'm sure i gained at least an inch up front from the change in suspension geometry due to my rear leaf spring over, because i had 5 1/2 inches above the front tires before the SOA and had 6 1/2 after (it was sitting on the trimmed upper bump stops) ... i turned down the torsion bars 10 full turns (40 one-quarter turns, didn't count how many threads) when i was replacing my cv axle recently, but only turned them back up about 3/4 of that and i still get a full 5 1/2 inches above the front tires (between the top of the tires and the bottom lip of the fender) ... basically when my rig is fully loaded with offroad gear and supplies the rear now has about 7 1/2 inches above the rear tires and 5 1/2 above the front tires, so it actually looks nice ... and the performance is sweet ... thanks for asking
PHP: 7.4.33 Page Time: 0.014s Queries: 14 (0.011s) Memory: 0.6258 MB (Peak: 0.7220 MB) Data Comp: Off Server Time: 2026-11-17 11:01:19 UTC
