Electrical problem, dead battery #213476 07/02/03 10:49 PM
tkal Offline OP
I dont know why. It acts like the alternator is dead, or the battery is not charging corretly.
After driving around for a bit the bat is a little low and cranking is a little slow. At one point after driving it, it would not start.
Today I go to her and put the key in, nothing completly dead. Dash, everything. There is no radio in the truck at the moment, wires are just bouncing around. I have pulled the fuse for it just now.
Any ideas?
'88 D-50 2.6 needs some love.
Re: Electrical problem, dead battery #213477 07/02/03 11:15 PM
Geophie Offline
Could be:
-starter guts filthy... (or starter dying)
-ignition switch
-dirty battery terminals/loose or dirty ground cable end... (low voltage from dirty terminals to a starter can put burnt spots on the starter's armature, i hear, causing premature failure of the unit)
-neutral switch?...not sure if this item being dirty would make your battery croak
-alternator
1991 4dr RS, ATK 3.0, auto. Now with zero trans fats!
Re: Electrical problem, dead battery #213478 07/02/03 11:33 PM
NathanC Offline
Did you swap in a different alternator with your rebuilt engine? I found out that an '85 alternator would not work in my '88. It would charge fine, but would drain the battery dead when the vehicle was not running.
Make sure all battery connections are good. Also make sure one of the fusible link connectors isn't loose.
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: Electrical problem, dead battery #213479 07/03/03 12:53 AM
tkal Offline OP
I think the starter is fine. If it was going bad it would not kill the dash lights.
I have never had a problem with the ignition switch, but will manualy crank the starter via screwdriver.
Will go over all wiring and termals (have not had time yet)
I dont think the 5 speed has neut switch.
Almost everything is the same. Block, battery, head, water pump are all new/rebuilt.
Re: Electrical problem, dead battery #213480 07/04/03 11:17 PM
tkal Offline OP
Alternator had bad bearings, but main problem still exists.
When I was installing the new alternator it had a warning tag saying that this post must be grounded to the battery in order for stuff to work. There was no wire going to there when I pulled the old one. There is another post that goes to the battery, positive now that I think about it. Then there is a 2 prong plug as well. Should something be connected to this 3rd post? I did not see a free wire any where.
Re: Electrical problem, dead battery #213481 07/04/03 11:54 PM
FranklinP Offline
Most Alternators ground through the frame of the alternator. A quick check with the volt meter will determine if extra ground is necessary. Check continuity from alt to gnd. Remember if the battery terminals are lose the alternator voltage will float high and likely burn itself up. Also be sure the battery is fully charged before you crank over the motor. Dont jump start it, the stress of charging a dead battery may blow out new alt. Good luck. Frank
1989 Dodge Raider V-6, 33" Swampers.
Raider pics
PHP: 7.4.33 Page Time: 0.008s Queries: 14 (0.006s) Memory: 0.6100 MB (Peak: 0.6793 MB) Data Comp: Off Server Time: 2026-11-16 08:39:55 UTC
