Page 1 of 4 1 2 3 4
ABS Light?? #220052 06/19/03 05:21 AM
LadyFrog Offline OP
ok....
ABS light came on so I checked the fluid level and looked at the lines...fluid is full and lines are all good.
However, the brakes had given a little squeak.
Can worn brakes cause the ABS light to come on???
or can it be something else?
<img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
<small>[ June 19, 2003, 01:20 AM: Message edited by: LadyFrog ]</small>
LadyFrog
I miss my little Kia
Re: ABS Light?? #220053 06/19/03 11:51 AM
Axe Man Offline
Kia Moderator Emeritus
Most likely it's a front wheel ABS sensor. Either dirty or connection loose. ABS systems can be a bear and turn into money pits if they break. But yea, I would check the condition of the front brake pads too.
I don't have ABS on my Sportage so I'm not up to speed on it's operation. But in a few days you will have a care package in the mail which should help. <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
<small>[ June 19, 2003, 06:54 AM: Message edited by: Axe Man ]</small>
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: ABS Light?? #220054 06/19/03 01:23 PM
Dave Scott Offline
my ABS light was on for years. i got a new suspension and it went out. my guess is the front end was dipped too much from sagged springs, or, there is a problem and the bulb burned out.
dave <img border="0" alt="[Shiner]" title="" src="graemlins/shiner.gif" />
Re: ABS Light?? #220055 06/20/03 05:08 AM
Same here. I have two 95 Sportages that I have had since they were new. The ABS light has been lit on mine for several years. However, I have had no issues with braking and nobody has been able to find a cause. I suspect it is a bulb, sensor or just faulty electronics. Not sure, I am not a mechanically inclined.
Keith
Re: ABS Light?? #220056 06/19/03 07:10 PM
LadyFrog Offline OP
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Axe Man:
<strong> But in a few days you will have a care package in the mail which should help. <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">thanks <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
should get it in about a week or 2 then...heh
mountain mail if it takes a day...
it'll take a week!... <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
lol
LadyFrog
Re: ABS Light?? #220057 06/19/03 10:07 PM
LadyFrog Offline OP
from what I'm reading in other posts...
lifetime breaks are bad?
so, if I can get 12 month breaks(Napa auto carries 12 month pads/shoes for the kia) they will be better in the long run for my car?
LadyFrog
Re: ABS Light?? #220058 06/19/03 10:12 PM
Axe Man Offline
Lifetime brake pads can be very hard on brake rotors. And Sportage rotors are trashy anyway. You are better off with a good OEM replacement like Wagner brake pads.
Re: ABS Light?? #220059 06/25/03 10:15 PM
LadyFrog Offline OP
ok with the help of a little care package that I recieved today....
I'm looking over my ABS stuff(technical term)...lol
seeing that it uses a fuse in the engine compartment fuse box, I thought I'd look over the fuse.
humm...does not look good seems all but one of the bigger fuses are corroded...the one not corroded...we had replaced.
should I replace all the corroded fuses?
they arent broken or burnt, just very heavy corrotion. <img border="0" alt="[Barf]" title="" src="graemlins/barf.gif" />
Thinking corrotion is never good but dont know if this may be the problem with my abs causing the light to come on???
LadyFrog
Re: ABS Light?? #220060 06/26/03 12:35 AM
Axe Man Offline
I'm glad the care package arrived OK. <img border="0" title="" alt="[Wink]" src="images/icons/wink.gif" />
Corrosion is never a good thing. I would remove the fuses and clean up the fuses themselves and the metal contacts on the fuse holder. Use emory paper or fine sand paper. If you don't have a test light or a DMM then take the ABS fuse to any auto parts store and they can test to see if it's OK. If it's bad, get a few of that type. Try one of the fuses. If it blows immediately that indicates a severe problem with the ABS. But I doubt that will happen.
Happy troubleshooting! <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
Re: ABS Light?? #220061 06/26/03 12:49 AM
joer4x4 Offline
Leaky brake cylinders or calipers and cause an ABS light.
<small>[ June 25, 2003, 09:03 PM: Message edited by: joer4x4 ]</small>
Later...
Joe R.
97 Kia Sportage - Eibach 2 lift , 30" A/T's, Warn manual hubs Hi-Lift, GPS.
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6371 MB (Peak: 0.7607 MB) Data Comp: Off Server Time: 2026-06-07 03:44:47 UTC
