Leaky Oil Pan #220318 07/02/03 06:19 PM
LadyFrog Offline OP
ok...I have a little oil leak from investigating the little bugger it seems to be coming from the top edge of the oil pan.
reading care package...
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans"> Oil Pan
1. Remove the oil pan mounting bolis.
2. lnsert a scraper or a tool between the oil pan and
the stiffener or cylinder block to separate them.
3. Remove the oil pan.
Caution
Do not damage or scratch the contact surlace
when removing the oil sealant. </font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">there is no gasket??.....just sealant?????
<img border="0" title="" alt="[Eek!]" src="images/icons/shocked.gif" /> <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
LadyFrog
I miss my little Kia
Re: Leaky Oil Pan #220319 07/02/03 06:30 PM
Axe Man Offline
Kia Moderator Emeritus
Yep, no gasket. But before concluding the leak is from the pan I would totally clean everything first with a spray can of degreaser and then wash it down with water. Go for a few days and then check again.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: Leaky Oil Pan #220320 07/02/03 07:41 PM
Dave Scott Offline
almost every vehicle i have ever crawled under is greasy in that area. it just happens. just make sure it doesn't get really bad because that could mean too much is coming out somewhere. my theory is that it sorta steams out when the oil is hot, but how shoudl i know, i'm not a mechanic.
Re: Leaky Oil Pan #220321 07/02/03 07:53 PM
LadyFrog Offline OP
it's just one little drip so I wiped it off with a rag and got a second oppinion from the big guy.
Going to clean it all over anyhow to make sure first...just to be on the safe side! <img border="0" title="" alt="[Razz]" src="images/icons/tongue.gif" />
humm... no gasket... I always thought of sealant as a "cant find the right gasket fix all".
never imagined it would be the original material!
<img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
LadyFrog
Re: Leaky Oil Pan #220322 07/04/03 04:54 AM
LadyFrog Offline OP
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Axe Man:
<strong>Yep, no gasket. But before concluding the leak is from the pan I would totally clean everything first with a spray can of degreaser and then wash it down with water. Go for a few days and then check again.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">humm...cleaned the engine as you suggested...
peaked at it a few times the past couple days....
there seems to be...no leak <img border="0" title="" alt="[Eek!]" src="images/icons/shocked.gif" />
no pesky drip at all...will keep an eye on it a few more days see what happens.
could it have been icky stuff from previous leaks getting hot and dripping off?...engine was pretty goobered and the valve cover gasket was leaking badly
LadyFrog
PHP: 7.4.33 Page Time: 0.007s Queries: 14 (0.005s) Memory: 0.6056 MB (Peak: 0.6705 MB) Data Comp: Off Server Time: 2026-06-09 21:42:26 UTC
