Well, I'm still here working on my conversion to my 1st gen 86 Trooper T/D. I'm currently moving the battery back under the rear seat so that I will have room for the SAAB intercooler I got off ebay last month. The old battery tray is out (I got one of those special drill bits that cut out
factory spot welds) and am I'm surprised at all the room I have there now. Gonna move the windshield wiper bottle to the other side, too. If I drop the front bumper a couple of inches or raise the body a little with a two inch kit, I'll be able to utilize one of the air inlets under the passenger side headlamp for the air I'll need for the intercooler. Did all this while I had the radiator out from doing the timing belt.
By the way, for all the c223 diesel trooper owners, the timing belt was tricky without the cam and pump lock much less not having the static gauge: first time I was a "tooth" off and got a lot nailing before I went back in and discovered my snafu. The injector WILL rotate a tooth when the tensioner is released to be replaced unless you have the inj pump lock. I searched all over the internet for an Isuzu diesel timing set and they are none to be found. I called a lot of dealerships only to find out that Isuzu is pretty much closing up shop all over the country. There is a cam locking pin that holds the injection pump in place while the belt is off, but I estimated where the belt was going to be when the roller (tensioner) was back in place and got it right on the mark (there are two arrows to help). Starts up and sounds good now. I still do have the problem of tightening the 39mm crankshaft end bolt to 50-60 ft-lb. The crank just turns when I try to tighten it now and the manual calls for pulling the starter and placing a flywheel lock in it's place. I don't think a eight year old could get their hands down in there to get to the starter bolts much less my big mitts. I think I'll use Locktight for now and torque when I pull the motor out to put into the 88LS unless someone else has a better idea.
I went over to Home Depot and picked up some small angle iron and mig welded up a battery box that will slip down into the square hole I will have to cut into the floor under the rear seat. Don't know if anybody is interested, but I
did take some pictures.
Jess
86 Trooper T/D
88 LS Trooper
