1" Body Lift, is it worth it? #225396 09/19/02 06:44 AM
dankman Offline OP
is a 1" BL worth the time, effort? thinking a 1"BL and a small amount of Torsion crank be enough not to rub 32"s or even fit 33"s.
1996 T100 4X4 on 33" BFG ATs, 2" BL, 5 spd
Re: 1" Body Lift, is it worth it? #225397 09/19/02 04:24 PM
With a 1" and some torsion bar crank, you could do 32's.
For all the effort, why would you not want to put a 2"? You could still put 32's if you wanted.
Just curious.
Re: 1" Body Lift, is it worth it? #225398 09/20/02 05:53 AM
Forget about 33" with a 1"BL -wont work. The 32" tires should fit without a BL so long as you are not running an aftermarket wheel that changes the back spacing. A 1" BL would be fine BUT don't do it to increase tire size, only do it to be 1" taller than the rest of the T100s. I did a 2" BL and I am happy with it every day (except when I see one with a 4" suspension <img border="0" alt="[Baby]" title="" src="graemlins/baby.gif" /> ) Just my opinion.
Re: 1" Body Lift, is it worth it? #225399 09/21/02 05:59 AM
dankman Offline OP
i have the 32s on right now, they're just rubbing lots...took a chunk off one of the lugs with i think one of the bolts that hold the mudflaps on...
i was thinking 1" BL cause I don't want to do too many mods - don't you have to bend the shifter or something. also, i don't like the look of trucks with body lifts too much, but now that i've been looking in to it more, since the body sits on the frame lower than on 'normal' trucks, a 2" might not be that bad...
whats all involved exactly with putting on a BL? talking all the extra stuff like radiator, bumpers, etc...
Re: 1" Body Lift, is it worth it? #225400 09/20/02 07:14 PM
surlynkid Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by dankman:
<strong>i have the 32s on right now, they're just rubbing lots...took a chunk off one of the lugs with i think one of the bolts that hold the mudflaps on...
whats all involved exactly with putting on a BL? talking all the extra stuff like radiator, bumpers, etc...</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">get a 2". the bumpers will work out fine. get a 2" motor mount lift from roger brown and you will nto have to do the radiator. do the 1" t-case lift and you will not have to do the shifter linkage. i did the 2" BL and am about to do the drivetrain lift.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: 1" Body Lift, is it worth it? #225401 09/20/02 09:43 PM
mikem Offline
So, does all that mean that if a guy only wanted to doa 1" lift, there would be no other mods required?
1995 T100 SR5 XCab 2WD Auto
Re: 1" Body Lift, is it worth it? #225402 09/21/02 12:45 AM
surlynkid Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by mikem:
<strong>So, does all that mean that if a guy only wanted to doa 1" lift, there would be no other mods required?</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">i do not knwo what you would do about teh fan and the shroud with a 1" lift. i would match it with a 1" drivetrain lift. hell, you are getting it all from roger anyway.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: 1" Body Lift, is it worth it? #225403 09/21/02 03:52 AM
mikem Offline
Who's Roger?
Re: 1" Body Lift, is it worth it? #225404 09/21/02 04:44 AM
surlynkid Offline
<strong>Who's Roger?</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">roger brown. he sells the 1" lifts.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
PHP: 7.4.33 Page Time: 0.010s Queries: 14 (0.007s) Memory: 0.6227 MB (Peak: 0.7246 MB) Data Comp: Off Server Time: 2026-11-02 08:04:54 UTC
