Iridium spark plugs? #227481 01/15/03 12:16 AM
T-Rex Offline OP
Recently, I've been hearing more and more on people using iridium spark plugs. I've heard many pros and cons doing search on the net. As far as I know, only NGK and Denso make them. Anyone experienced with iridium plugs on their Toyota or others? Sounds great, except for price.
02 Tacoma Double Cab TRD Prerunner .. just added 3" lift .. more to come
Re: Iridium spark plugs? #227482 01/18/03 02:06 AM
Arrowhead Offline
I slapped a set on @ $6 per plug. My conclusion after 20K is the iridium is the same as the platinum, platinum 2, platinum +4 and the ON SALE 99 cent autolights. I don't think I'll get over 40K on the iridiumÆs. $1.29 NGK's will give you everything the $6 iridium's will. Unless you need a special plug to run at a certain temperature for a special application don't bother paying more than $1.50 a plug.
Re: Iridium spark plugs? #227483 01/21/03 06:43 AM
uzombie Offline
I had the +4 Platinums and the first 2500 miles it was improvement. But then its been pretty expensive investment ever since. I would stick with NGK. Plugs get fowled and carbon'd.
Just remember to puta dab of Anti-seize on the threads...makes live a whole lot simpler when it comes to removing them later <img border="0" title="" alt="[Wink]" src="images/icons/wink.gif" />
Hope all are well! Still got the T...
Re: Iridium spark plugs? #227484 01/20/03 07:03 PM
surlynkid Offline
i bought some OEM platinum ones but have yet to install them.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Iridium spark plugs? #227485 01/20/03 07:36 PM
4
4xGeek Offline
Don't know much about the iridium plugs, but I picked up a set of Bosch platinum 2's... Minor improvement, but most of it can probably be attributed to the worn condition of my old plugs.
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: Iridium spark plugs? #227486 01/20/03 08:18 PM
surlynkid Offline
platinum just takes longer to erode and widen the gap. that is the only value i see. i am not thrilled with changing plugs all teh time, so platinum sounds nice.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
PHP: 7.4.33 Page Time: 0.010s Queries: 14 (0.007s) Memory: 0.6075 MB (Peak: 0.6760 MB) Data Comp: Off Server Time: 2026-11-02 09:59:55 UTC
