Re: Ye Olde Clutch Pedal Bracket (with pics!!!)
#228542
02/28/06 03:57 AM
we just did trdjustin's on saturday. remove the two nuts at the master cylinder under the hood. remove the pedal. remove the bolt from teh inside that goes through the firewall. pull it out. add stiffening plate to engine bay side, and put it all back together. get the two little bushings as well.
Scott Landon 1995 T100 - total buildup underway 1988 4Runner (22RE, W56) - new DD 2005 Dodge CTD 4x4 - Tow Beast 1990 Spec Miata 2010 GT3 2013 E92 M3
[Re: surlynkid]
#228543
02/28/06 05:29 AM
The same thing happened to me on my 96 T-100. I ordered the new pedal, and before I installed it, I welded the seams, and gusseted anything that looked weak.
[Re: Perpetrator]
#228544
03/05/08 12:35 AM
Could you or anyone tell if the bracket was cracked while inspecting it still installed on the truck....96 t100 3.4 2wd, replaced clutch, master, and slave, had it bled by toyota - need a little help here....does it have to be removed for inspection?
[Re: bigadventures]
#228545
03/05/08 05:34 AM
You should be able to tell by shining a flashlight up there and looking in between the fork. You could even take a piccie with yer digital camera set on macro. Cameras have a tendency to see things with the flash that yer eyeballs can't see especially if yer old... If the flash is too bright, put a small piece of a paper towel over the flash...;) Just don't run yer bare finger over that area...too easy to git cut! <img src="/forums/images/graemlins/frown.gif" alt="" />
If you truly want to be sure...I'd take it off and inspect it carefully.
[Re: surlynkid]
#228546
03/10/08 12:12 AM
wowza an all this time i thought i needed a new clutch, looked under and whaddaya know? my question ... does anyone know if they are the same for two and four wheel drive models? 97 t-100 2.7 litre 2 wheel driveis what i have. also has anyone found any aftermarket parts cheaper than going with toyota,cause they seem to want an arm and part of the torso. any help would be appreciated LFV
[Re: louisypher]
#228547
03/10/08 12:16 AM
I believe they would be the same part. It wouldn't make sense to have a different one...kinda like a 4WD or 2WD gas pedal... <img src="/forums/images/graemlins/wink.gif" alt="" />
If you want to go cheap, you could probably duplicate the mod to the bracket (bigger shims) or tie a U-bracket across both ears of the bracket to the top of the plate and distribute the force across the entire plate instead of just the sides of the plate. Have someone build and weld that up fer you and you should be good to go! <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: BamZipPow]
#228548
03/10/08 01:46 AM
wow thanks for the quick answer <img src="/forums/images/graemlins/lol.gif" alt="" />i was just wonderin if there were aftermarket manufacturers.but then t-100's werent exactly big hits in the industry.nope just have to bite the bullet,my welder freind is too busy as it is.thanks for the help! but to make light, the exterior door handles are different between 4x's and 2x's LOL go figure. LFV
[Re: louisypher]
#228549
03/10/08 01:49 AM
The exterior door handles are different? How? I got a set from a T100 4x4 and they fit fine on my T100 4x2 without any problems... <img src="/forums/images/graemlins/wink.gif" alt="" />
Both were the chrome plastic ones... <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: BamZipPow]
#228550
03/10/08 01:55 AM
well now this was according to the local toy shop,but now i can buy a chrhome set from elsewhere,question on those chromies...is it metal all the way through cause that seems to be where mine break, at the little foot,gone through two pair now,an its not as if i use a sledge to open the door.course the ones i bought were aftermarket cheapies, if you call 27$ per cheap.
[Re: louisypher]
#228551
03/10/08 01:57 AM
whoops read ur post again.. dangdit ,wish they would use at least pot metal or something...wood, would be better than plastic <img src="/forums/images/graemlins/confused.gif" alt="" />
