Page 4 of 4 1 2 3 4
Re: Ye Olde Clutch Pedal Bracket (with pics!!!) [Re: louisypher] #228552 03/10/08 03:12 AM
BamZipPow Offline
After breaking my driver's handle one day, I modded the driver's side by aligning both pieces and drilling a hole through them, put a big nail (trimmed to size) in there as a support piece. Expoxied the set together...guaranteed not to ever break again under load...unless someone smashes it with a sledgehammer or car wreck. <img src="/forums/images/graemlins/wink.gif" alt="" />
I originally tried to epoxy them together without the nail and it just re-snapped off. I knew then I needed some extra support from some steel/iron! <img src="/forums/images/graemlins/smile.gif" alt="" />
Haven't used the 2nd set that I got both (factory chrome driver and passenger handles) fer $7. <img src="/forums/images/graemlins/wink.gif" alt="" /> I'm tempted to mod those out before I ever install them so it will have some decent support! <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Ye Olde Clutch Pedal Bracket (with pics!!!) [Re: BamZipPow] #228553 03/10/08 04:02 AM
L
louisypher Offline
good idea, not like i am short of handles to expiriment on.thanks for the inspiration.
Re: Ye Olde Clutch Pedal Bracket (with pics!!!) [Re: surlynkid] #228554 05/01/08 04:29 AM
Tirya Offline
we just did trdjustin's on saturday. remove the two nuts at the master cylinder under the hood. remove the pedal. remove the bolt from teh inside that goes through the firewall. pull it out. add stiffening plate to engine bay side, and put it all back together. get the two little bushings as well.
Having just spent an hour under a friend's '95 T-100 trying to figure out whether he needed a new clutch, I am SO glad I found this before he brought it to the shop!! This sounds like it might be the problem - the clutch switch won't engage (the clutch pedal doesn't hit it right, we ended up taping it down); there's a popping noise from the area of the master cylinder when the clutch pedal is pressed and let out; and the transmission won't come out of or go into gear when the engine is running.
Thanks, all! Here's hoping...!
Re: Ye Olde Clutch Pedal Bracket (with pics!!!) [Re: Tirya] #228555 02/12/09 07:41 PM
9
90twodoorrunner Offline
Just wanted to add Part #'s for a different year.
1990 4runner V6 4x4
Clutch sub assembly bracket # 55106-35050 Will fit 1990, 1992-1995 4 runner automatic or manual 4 or 2 wheel drive. Price at dealer $179.02
Clutch spring bushings # 90386-04009 Wil fit 1986- 1995 4runner(and others) Price is cheap, under $5 I think I did not check.
1990 4x4 4runner 3.0L V6
the mystical two Door unibody
Re: Ye Olde Clutch Pedal Bracket (with pics!!!) [Re: jroc] #228556 02/15/09 12:36 AM
ToyGearhead Offline
I have the same problem in my 95' T100. The truck is setting on 198k & I thought it may need an entire clutching system overhaul in the near future, but now I'm sure that its the bracket. Know any links or sites where I could find one w/ the price??? I find my local parts houses don't have alot of T100 parts available. I am still planning clutch work in the near future, probably a Centerforce Performance clutch. Any advice or info on these things would be much appreciated.
1995 Toy T100 DX Xcab 4x4 3.4V6 5sp. 32/11.50/15 Destination MT's -TRAILRIDER
Re: Ye Olde Clutch Pedal Bracket (with pics!!!) [Re: ToyGearhead] #228557 02/15/09 03:19 AM
E
eleet Offline
Dealer. If you need a dealer, call Gettel Toyota. Our friend there will not make you pay double as a walk in the way your local dealer might.
You will not realize any benefit from the centerforce clutch. Use a clutch kit from Aisin or Sachs instead. If properly installed it will stand up to all the torque that your engine can make.
97 T100 4x4
97 328i
95 540i restoration project
Re: Ye Olde Clutch Pedal Bracket (with pics!!!) [Re: eleet] #228558 02/15/09 08:17 PM
ToyGearhead Offline
I appreciate the info. I'll be looking into this. Thanks again
Re: Ye Olde Clutch Pedal Bracket (with pics!!!) [Re: Perpetrator] #228559 01/04/11 02:12 AM
jshryder Offline
so where do you get to the bolts that are left on it, I can't seem to find where they are through the firewall
Re: Ye Olde Clutch Pedal Bracket (with pics!!!) [Re: jshryder] #228560 01/17/11 03:34 PM
Perpetrator Offline OP
As I recall, the bracket is held on with the two studs that poke through the firewall that the master cylinder mounts to. Is that what you are asking?
1997 T 100 4X4 ExtraCab
5 speed, White
Worthless factory bedliner
265/75/16 Firestone Destination A/Ts
Aisin Manual Hubs
90k miles
Page 4 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6376 MB (Peak: 0.7570 MB) Data Comp: Off Server Time: 2026-06-07 02:18:25 UTC
