t100 brakes #229499 04/19/03 05:48 AM
vrooooom Offline OP
what is involved in putting t100 rotors and t100 calipers into a 94 pickup? is it a direct bolt in?
what about the tundra brakes? are the tundra brakes beefier and will they fit the pickup?
thanks.
stock 1994 Toyota 4x4 XtraCab v6 SR5 pickup
Re: t100 brakes #229500 04/19/03 01:43 PM
surlynkid Offline
i think they are the same. the IFS is all the same, so i cannot imagine why the brakes would not bolt on.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: t100 brakes #229501 04/20/03 03:17 AM
vrooooom Offline OP
thanks
Re: t100 brakes #229502 04/21/03 04:36 PM
ErikB Offline
Toyota Moderator
The rotors are thicker on the T100 (24mm vs. 18mm), and the calipers are built to match, but if you swapped them both in, I don't see why they wouldn't bolt right up. <img border="0" title="" alt="[Smile]" src="images/icons/smile.gif" />
http://home.4x4wire.com/erik
Re: t100 brakes #229503 04/22/03 05:05 AM
jroc Offline
I am helping Churnd (on the boards) replace his rotors and they are not the same (as ErikB stated). He has a 94 Mini also. The T's are thicker. As far as the swap, wonder if the larger T100 calipers are a direct bolt up (do the holes line up?) The rotors might work with the hubs but the calipers might be a different story.
PHP: 7.4.33 Page Time: 0.007s Queries: 14 (0.004s) Memory: 0.6007 MB (Peak: 0.6635 MB) Data Comp: Off Server Time: 2026-06-25 04:01:17 UTC
