Hi Folks,
My 99 Tacoma with 125K miles appears to be having a rear axle oil seal leak from both sides. They started leaking about a month after I installed a lockrite in the rear. I replaced the diff breather, and they stopped leaking. About two weeks later, they started leaking again. The new breather seems to be fine.
I checked the tech articles in the Toyota maintenance section and found a good write-up on replacing the rear axle oil seal. The write-up mentioned replacing rear axle flange gasket with a new one. Unfortunately, I don't remember ever seeing a rear axle flange gasket when I removed the axles to install the lockrite. The write-up appeared to be of an older, pre-Tacoma truck, so I don't know if the Tacoma is supposed to have a rear axle flange gasket. Even if it is or not, could the lack of one cause a rear axle leak anyway?
Any ideas as to why both sides would leak, then stop leaking, and then start leaking again?
I have most of the parts available to replace both rear axle oil seals myself. But I'd hate to have to go through the trouble of replacing them just to have them leak again. I read one of the threads in the tech archives on a rear axle oil seal that repeatedly failed after several replacements. Although there is some good advice mentioned in that thread, there did not appear to be a conclusive remedy for fixing that problem. So any ideas would be appreciated on preventing repeated rear axle oil seal failures.
Thanks for any extra info and take care,
