Body Lift--have kit, how long? #236152 05/28/03 06:47 AM
hfoobe Offline OP
For you people who have done a body lift, is it an afternoon project, or what?
Trying to plan ahead.
I have the 2" kit from 4wheelparts.com, working on an 86 Pup. <img border="0" alt="[Chicken]" title="" src="graemlins/chicken.gif" /> <img border="0" alt="[Nerd]" title="" src="graemlins/nerd.gif" /> <img border="0" title="" alt="[Smile]" src="images/icons/smile.gif" />
Re: Body Lift--have kit, how long? #236153 05/28/03 07:04 AM
maxwell417 Offline
It took me, by myself, 10 hours in a fully equiped shop. I am not a mechanic by any means. It took me a couple hours messing with a captured nut <img border="0" title="" alt="[Mad]" src="images/icons/mad.gif" /> that spun. Had to cut a hole in the floor to get at it. It was fairly easy job and I'd do it again. If your like me, start on Saturday morning and if things go bad .... well you still have Sunday.
Start spraying rust penetrant on your body mount bolts now, repeat daily. I twisted off 2 bolts and spun 1 nut. Even though I sprayed for 2 weeks.
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: Body Lift--have kit, how long? #236154 05/28/03 02:03 PM
RobG Offline
I'd plan 2 days and try to have a helper if you can. It can be done in shorter time, by yourself, but i'd plan 2 days, 2 people.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 38x13 TSLs, spooled D60 front, 14bff rear locked by detriot, high steer w/ hydro, dual Isuzu tcases.
Re: Body Lift--have kit, how long? #236155 05/28/03 03:36 PM
Richard Saylor Offline
It took me 4 or 5 hours to do it by myself. That's also having done it once before, so if you've never done it then it might take longer for you to get the hang of it. I started one evening around 6, got the cab done and bolted by 8. Decided to leave the bed for the next day. Got out around 10 and had the bed done by 12 or 1. That's also with having to go the hardware store and buy bolts since the ones that were supplied were too long. So, could you get it done in an afternoon? Yes, but I would start it on like a Saturday and that'll give you the rest of the weekend if you run into problems.
Richard
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: Body Lift--have kit, how long? #236156 05/28/03 06:05 PM
it took me two days to put it on my 95.5 rodeo and took me one day to take it off!!
Re: Body Lift--have kit, how long? #236157 05/28/03 09:42 PM
AIR AMIGO Offline
Helper avail here....call me tonight. 425-503-3617 on my cell.
Keith
"AIR AMIGO!" aka 1994 Isuzu Amigo SAS with Toyota axles, 5.29's, dual ARB's, IROK's, WARN HS9500 winch, and etc.
Pacific NW Isuzu Off-Roaders
Timber Tamers #172
Re: Body Lift--have kit, how long? #236158 05/29/03 12:31 AM
rodeo_chris Offline
The pickup should be easier to do than the trooper/rodeo/amigo's due to the fact that you can lift the cab and bed separately. Save your back and pull everything out of the truck that would get in your way and increase weight(seats, toolbox, battery, radiator, carpet, bumpers, etc.)
-chris
<small>[ May 28, 2003, 07:32 PM: Message edited by: rodeo_chris ]</small>
94 Rodeo, 35's, 5.38's, locked F&R, Rocker bar on one side, other side in garage
96 Tacoma, DD, pre-dented
Re: Body Lift--have kit, how long? #236159 05/29/03 12:49 AM
one problem i had when i lifted my truck was the kit came with 1)wrong bumper bracket or 2)one hole for the bumper bracket was missing. anyhow, i went ahead and drilled and bolted up a new hole to help out. hopefully the 3" BL kit i just ordered will have the correct bracket.
Brandon
p.s. make sure to check ALL your lines and hoses (i.e. heater hoses, power steering, and anything that is connected to the body and the frame) before you lift it. also, to put the steering extention on, the only time you can put it on is when the drivers side is jacked up. good luck <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
Re: Body Lift--have kit, how long? #236160 05/29/03 02:42 AM
plan on a week end and a second person helps alott. did my 91 troop. And that captured nut bs sucks, mine was on my mount at my driver side at the back door. Took a couple of hours to cut open the bod then butcher out the S O B. Time and planning, also the hoses going to the heater core take time to extend several people have had them tear if not me included. also after a little time go bacl and retighten ALL your bolts. And my PAW kit bumper brackets i ended up not using.
GOOD LUCK
Re: Body Lift--have kit, how long? #236161 05/29/03 03:45 AM
hfoobe Offline OP
Jesuscanizo, why did you take it off?
Everybody, thanks for the stories. And the advice. I'm out there with my can of penetrating oil. and I will start early on a Saturday. <img border="0" title="" alt="[Wink]" src="images/icons/wink.gif" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6382 MB (Peak: 0.7562 MB) Data Comp: Off Server Time: 2026-06-07 09:31:42 UTC
