Block bolt pattern #237188 06/28/03 03:56 AM
G
Greg55_99 Offline OP
OK, I've got an important question. Are the bellhousing bolt patterns on the 3.2 and 3.5 the same as the GM FWD pattern?
Greg Williams
Re: Block bolt pattern #237189 06/28/03 05:12 AM
Richard Saylor Offline
I'm almost positive they're not. The 3.2 and 3.5 are Isuzu engines and not GM engines.
Richard
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: Block bolt pattern #237190 06/28/03 06:06 AM
randii Offline
Not even close. <img border="0" title="" alt="[Frown]" src="images/icons/frown.gif" />
Randy Burleson
4x4Wire Managing Editor Emeritus
Mongrel Isuzu Amigo
Re: Block bolt pattern #237191 06/29/03 05:47 AM
Ed Mc Offline
Jerry Lemond told me a while back that a 3.4 would bolt up to the later tranny. Has anyone ever actually sat them down side-by-side to do a comparison? Jerry usually knows what he's talking about.
'90 Troop 3.4 LS
'89 Troop RS (Has Valve Issues, needs Counseling)
HI, I'm Ed and I'm a Trooper-holic!
Keep On Troopin'......
Re: Block bolt pattern #237192 06/29/03 12:39 AM
G
I'm also wondering if the AR5 is a close relative of the Toyota R151F. Can anybody confirm that?
Greg
Re: Block bolt pattern #237193 06/29/03 10:49 PM
randii Offline
I have the spacer plates from multiple tranny variants -- the one for the 60-degree V6 is quite a bit different than the Isuzu 3.2/3.5 V6 plate.
Randii
Randy Burleson
Mongrel Isuzu Amigo
Re: Block bolt pattern [Re: randii] #237194 11/08/03 04:06 AM
Bruce Anderson Offline
Howdy Randii
So like would you like this opportunity to revise and amend your previous comment?
<img src="/forums/images/graemlins/evil.gif" alt="" />
See Ya
Bruce
Re: Block bolt pattern [Re: Bruce Anderson] #237195 11/08/03 05:21 AM
houlster Offline
Isuzu Moderator
Randii
Howdy Randii
Watchyer back Randy, he's setting you up. (hint hint, think about it. Just because the plates you have for the 3.2/3.5 are different than the 60 deg V6, doesn't mean those plates are the *only* ones that'll fit the 3.2/3.5...)
--Dan
Re: Block bolt pattern [Re: houlster] #237196 11/08/03 02:58 PM
G
If you look at Michael J. Wood's website, you'll see at the back of the block it has a "dual" bolt pattern. The inside pattern is the GM 60 degree one.
http://www.mjw.com/amigo/marlin/index.shtml
Greg
Re: Block bolt pattern [Re: houlster] #237197 11/08/03 10:53 PM
Come On DAN!!!
I only get to get over on somebody every 5 or 6 years or so. <img src="/forums/images/graemlins/barf.gif" alt="" />
Thanks to Greg, Dan and Jerry, for the help on the 3.2-3.5 bolt patterns.
Looks like the swap picture includes all 60 degree GM engines. Seems they will all bolt to the 4L30-e
SWAPORAMA!!!!
See Ya
Bruce
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6397 MB (Peak: 0.7582 MB) Data Comp: Off Server Time: 2026-07-14 08:17:29 UTC
