22re oil loss problem please help #16845 04/25/03 01:11 AM
N
nachomama420 Offline OP
i have an 89 4runner with a 22re and am having an oil loss problem.... it is some how building up pressure and blowing my dipstick out and squirting oil out of it all over my hood and engine.. the pcv valve is good and i dont know why else this would happen, any suggestions would be appreciated thanx
89 4Runner, 5-speed, Rebuilt 22RE EFI, DOA C270 cam, Pacesetter Headers, 35x12.50x15 MT/R, 4" Superlift Susp, 3" Body Lift.
Re: 22re oil loss problem please help #16846 04/25/03 01:22 AM
Do you have too much oil in it?
Re: 22re oil loss problem please help #16847 04/25/03 02:20 AM
Bonzai Offline
If you are sure the pcv is good, make sure the hose isn't stopped up with goo. Ask me how I know that one! <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
89 Toyota P/U, 22re, SAS, 4" All-Pro Fronts, Chevy rears, 33x12.50's...
Re: 22re oil loss problem please help #16848 04/25/03 02:38 AM
N
PCV is clear, no blockage.
Oil level is good, however it is very dirty.
Re: 22re oil loss problem please help #16849 04/25/03 09:52 AM
Esquire812 Offline
*I highly suggest you do a compression check on all 4 cylinders. Hopefully I'm wrong on this one, but you will more than likey find one cylinder well below standard 125-175 PSI. Dont ask me how I know this one. Pulled my hood off sunday to get all the oil from under the ribs...looks really nice. Will look good while off the truck next week while Im doing "other" things. GRRRR ~Darin <img border="0" alt="[Baby]" title="" src="graemlins/baby.gif" />
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: 22re oil loss problem please help #16850 04/26/03 06:38 PM
David_M Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans"> *I highly suggest you do a compression check on all 4 cylinders. Hopefully I'm wrong on this one, but you will more than likey find one cylinder well below standard 125-175 PSI. </font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">I had this issue too.. My head gasket blew just a little in one of the oil ports "Exaust in the oil". The pressure was far more than the PCV could handle...
Re: 22re oil loss problem please help #16851 04/30/03 12:52 AM
N
well i just did a compresion test and cylinder #2 is only getting 30 to 50 psi.... its not the rings, cause i tried oil in the cylinder, so its down to valves or head gasket....the head gasket was replaced recently but i dont know how good of a job was down, the oil is mirky looking but i dont know if it is coolant or exhaust... is there a way i can tell, any help would be greatly appreciated
Re: 22re oil loss problem please help #16852 04/30/03 01:53 AM
Esquire812 Offline
First of all Mirky...if you mean milky than its moisture in the oil, coolant-rain water something. Think of oil going in fresh...all golden and shiny. Look at your oil, does it resemble grey or white vs. new golden brown?
About the "its not the rings" diagnosis...you may be surprised. What was the wet compression results on #2? In comparison, how did #1,3 and #4 compare? I recently experienced an engine that ran fine but had a "noise" that was deafening that quickly went away. Compression check revealed 145,145, 145, 60. Wet test brought the low cylinder up to 100#. Diagnosis, ring land broke...if not the #2 compression ring itself. Only way to tell where its going is to do a leak down. Pump about 30 PSI into the cylinder and listen. If it comes out the exhuast-ex valve, if it comes out T-body-intake valve, if it comes out radiator...cracked head or failed head gasket. If it comes out the oil cap...Engines coming apart soon. The high pressure in your oil pan pushing the dipstick out is enough for me to decides which it'll be. Good luck on your diagnosis and repair. ~Darin <img border="0" alt="[Baby]" title="" src="graemlins/baby.gif" />
PS-will have an updated signature next week....
85' Sillyca 22R-Esq
Re: 22re oil loss problem please help #16853 05/04/03 02:23 AM
N
The oil is pretty much how you described it, milky. Also found some in the fuel injection, must be coming back through pcv.
Pumped some air into the cylinder that was low and heard it coming out the radiator, but nothing coming out the valves. Sounds like the head gasket. Thanks for the advice, much appreciated.
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.004s) Memory: 0.6246 MB (Peak: 0.7229 MB) Data Comp: Off Server Time: 2026-06-24 10:09:22 UTC
