Spline Count on V6 Auto Tranny #17753 05/01/03 07:32 AM
Leo Offline OP
Anybody know the spline count of the V6 Auto Tranny on my 95 4Runner?
2000 - Tundra, V8 2WD Access Cab
Re: Spline Count on V6 Auto Tranny #17754 05/01/03 02:18 PM
I'll bite.
Why do you want to know that <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
Re: Spline Count on V6 Auto Tranny #17755 05/01/03 03:39 PM
Leo Offline OP
I'm gonna order a CV rear d-shaft from Jesse at High Angle Driveline. I wanted to know before I take it apart.
Re: Spline Count on V6 Auto Tranny #17756 05/01/03 03:40 PM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Leo:
<strong>I'm gonna order a CV rear d-shaft from Jesse at High Angle Driveline. I wanted to know before I take it apart.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Why do you need the spline count on the tranny for this? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Re: Spline Count on V6 Auto Tranny #17757 05/02/03 05:17 AM
anthony1 Offline
Hey what's going on with your truck man....
did you just want to get smaller shaft so it won't rub the gas tank?
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are.
It's freedom OF religion not from.
95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
Re: Spline Count on V6 Auto Tranny #17758 05/02/03 01:13 AM
OK from looking at your page I see you have some suspension lift etc so the reason is clear.
But you shouldn't need that info as Jess's driveline should include flanges that will bolt directly to the current flanges on your auto and third member. Unless part of his special driveshaft means he replaces this with a CV etc in which case you do need it, LOL. Let us know as I have some auto's in the shed and can remove the rear flange and check for you.
I just received a special pinion flange he makes to fit the Dana44 with a Toy driveline flange so I don't have to swap to a Dana flange on the driveshaft.
<small>[ May 01, 2003, 08:17 PM: Message edited by: JD_Ozrunner ]</small>
Re: Spline Count on V6 Auto Tranny #17759 05/02/03 06:50 AM
Leo Offline OP
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by JD_Ozrunner:
<strong>OK from looking at your page I see you have some suspension lift etc so the reason is clear.
I just received a special pinion flange he makes to fit the Dana44 with a Toy driveline flange so I don't have to swap to a Dana flange on the driveshaft.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">There's a long story to why I need a d-shaft but I won't go into that. Jesse will have to make me a new flange that bolts to the transmission. His CV joint will not fit the bolt pattern that I have on the stock d-shaft. I do appreciate if you could count spline for me.
PHP: 7.4.33 Page Time: 0.010s Queries: 14 (0.007s) Memory: 0.6100 MB (Peak: 0.6828 MB) Data Comp: Off Server Time: 2026-11-02 09:59:49 UTC
