Page 1 of 3 1 2 3
Fuel Gauge Sending Unit #249711 03/05/03 01:05 PM
LetsRodeo Offline OP
Eureka!
I've been driving around the last few months always wondering just how much gas I really had in my tank because of a faulty fuel gauge. I had priced a new fuel sending unit (gauge and pump) from the dealer at $318 and a salvaged one at $127. I couldn't locate just the fuel gauge element itself. I didn't want to buy a used assembly because I was afraid I'd have the same problem again in a short time with a used one.
Sunday I dropped my empty fuel tank and pulled out the assembly. After closely inspecting the fuel gauge element I determined the spring steel wiper assembly had worn out and was not making contact with the resistive circuit board.
This assembly is a simple device that utilizes a float, linkage and a wiper circuit board component. The wiper has two arms that wipe across two foil strips on the circuit board. It was the spring steel wipers that had worn out and no longer made contact with the circuit board foil.
I disassembled the unit and carefully reshaped and bent the spring steel wiper to establish good contact again. After putting it all back together and adding 6 gallons of gas, I turned the ignition switch on and waited a little while for the averaging circuit to compute the new level and Eureka! It works! It registered a little above a 1/4 tank. <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
If you want something done right do it yourself two or three times!
LetsRodeo
1999 Isuzu Rodeo LS 4WD
3" CPL, 3" BL
LT265/75 16 TOYO Open Country AT
ShrockWorks Rock Sliders
Re: Fuel Gauge Sending Unit #249712 03/05/03 03:47 PM
rubo Offline
Daaaaam you'r good. I would never even bothered to fix it.(i do have the same problem).
Now i have to put it on my to do list.
Don't you just love this place? Some one always will come up with some thing to keep you bussy <img border="0" title="" alt="[Razz]" src="images/icons/tongue.gif" />
rubo
"If i can't crawl over it, i'll fly over it"
rubo
'96 Amigo 4x4, 3.2L V6, 4L30E, D44 rear, SOA, 1" BL, undergoing surgery.
'00 Rodeo LS 4x4, 3.2L V6, OME 919 Springs, front cranked to match,1" BL, 265/70x16 Scorion A/T's.
Re: Fuel Gauge Sending Unit #249713 03/05/03 07:30 PM
Do you know if that's the same type of assembly in the 1st gen. Troopers?
I've been running on a full tank depending on the idiot light for 5 years!
Yeah, yeah lazy but the fuel sender unit croaked about 2 months after I dropped a FULL tank to replace the fuel pump and it was suck a POS that I wasn't in a hurry to repeat.
Re: Fuel Gauge Sending Unit #249714 03/05/03 08:22 PM
Jim_Paget Offline
I have a pump out of a 1st Gen V6 Trooper in the garage. I will check it out this afternoon.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Fuel Gauge Sending Unit #249715 03/05/03 09:27 PM
I had to replace the unit in my 99 Passport. Mine would read fine and then it would just drop like my line had busted. All the way to empty with idiot light flashing. I took it to my dealer, (it's Certified!) and he "couldn't recreate the problem." Later, after my ignition column assembly fell out (not good), I had it in and told them to check it out again while they had it. After the tech got the key to work, he started it up to drive it in a bay to check everything out. On the way into the bay, the gauge dropped to rock bottom again and the tech supposedly slammed it in park, turned it off and ran for a bucket yelling, "It's dropped it's tank!" Everyone looked at him like the screaming idiot he was. He turned around and noticed it was fine. Problem duplicated. Fixed under warranty. I'm keeping my eye on it. Thanks for the "easy fix" of that type of problem.
Re: Fuel Gauge Sending Unit #249716 03/06/03 12:35 AM
Jim_Paget Offline
I just checked the spare pump that I have for a 1st Gen Trooper with the V6. The sending unit is not part of the pump.
Jim Paget
www.rrr4x4.com
Re: Fuel Gauge Sending Unit #249717 06/23/03 01:34 AM
I was getting the P0463 Code (voltage too high in circuit), so I lowered the fuel tank to see if I could find what was wrong.
My circuit was getting the estimated 5 volts in the harness, so I am assuming that the probelm is in the fuel level sending unit.
I tried fixing my Fuel Level Sending Unit myself (like LetsRodeo), but one of the contact leads snapped off. I knew that was going to happen!! But I gave it a shot anyway. After my second attempt to make good connection, one snapped off.
It was worth a shot but now I'm gong to have to buy a whole new unit. It should cost approximately $250 for the assembly.
I'll post my results when I'm done.
-Chughead
Re: Fuel Gauge Sending Unit #249718 06/24/03 01:58 PM
I put the new fuel pump/sending unit into the tank yesterday. The fuel gauge is now working great.
Also, before I changed these, my 00' Rodeo would sporadically have a hard time starting. So far, it has started really fast every time. I am hoping that the new pump fixed that problem as well.
-Chughead
Re: Fuel Gauge Sending Unit #249719 06/26/03 04:21 AM
AAAAhhhhhhhh???????????
Does anyone see a problem here?
I have a 98 Rodeo that has had a bad sending unit on it since about 78,000 miles on the odo (currently 106,300 ) and I have lived with it.
I have heard on 2 different occasions thru this forum, that others have had them fixed under warrantee. But have had them go out break again innearly as many miles as it took to make the factory original one break.
In other words ISUZU has not fixed the problem, just postponed it till it was no longer covered under warrantee.
I also believe this is the same situation with all ISUZU's made by ISUZU since the mid 90's to current year models.
A coworker of mine has a 2000 Trooper and is starting to experience the same symtoms I had shortly before my gauge stopped working.
And this thread just provides positive proof to the matter.
I priced a new sending unit at the dealer with them installing it would run me about $700. Thats $250 for the part and the rest is labor.
I think we need to make this problem known to Consumer Reports ( CR ) and/or National Highway Traffic Safety Association ( NHTSA )
Are you all up to it?
I am going to file a complaint tonight on there web site ( NHTSA ).
Join in!
It took a while with the ABS problem but it works.
Thanks
Scott
Re: Fuel Gauge Sending Unit #249720 06/26/03 05:04 AM
Ok I filled the complaint!
Here is the web page below.
NHTSA Complaint form
I did a quick search and starting with 1996 and someone just filled a complaint today for the same problem with there 96 Trooper.
OOOHHH the power of the WEB!
Get to it everybody.
scott
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.018s Queries: 15 (0.014s) Memory: 0.6313 MB (Peak: 0.7549 MB) Data Comp: Off Server Time: 2026-11-17 11:03:48 UTC
