J. Paget RE: Speedbleeders........ #249732 03/05/03 02:08 PM
Forgive me if I missed something, but I didn't post this on both message boards..............
2001rodeo
Need a Spot!
Member # 6618
posted February 28, 2003 01:55 PM
I have a 2001 Rodeo 2wd with front disc and rear drum brakes. Has anyone purchased SpeedBleeders for this setup and do both front and rear use SB7100? Thanks in advance.
G
Posts: 13 | From: Charlotte, NC | Registered: Dec 2001 | IP: Logged |
isuzu95
Member # 5241
posted March 02, 2003 02:05 AM
Are the rears really drum style or are you referring to a parking brake? Pardon my ignorance, but it's been my understanding that manufacturers abandoned drum style brakes some time ago.
Posts: 68 | From: U. S. A. | Registered: Jul 2001 | IP: Logged |
J Paget
Isuzu Forum Moderator
Member # 1930
posted March 02, 2003 12:47 PM
Please don't post the query to both the Tech and Talk Forums. Nearly everyone reads both.
Since you have received more responses to your Talk post, I am going to close this one.
Jim Paget
'91 Trooper
Posts: 1548 | From: Sammamish, WA, USA | Registered: Aug 2000 | IP: Logged
Re: J. Paget RE: Speedbleeders........ #249733 03/05/03 02:11 PM
By the way, I'm looking for the correct part number for the rear drums, the fronts are sb7100 I know that, but I can't get anyone to confirm that they will work for the drums....even Speedbleeder themselves.
Thanks
Re: J. Paget RE: Speedbleeders........ #249734 03/05/03 04:57 PM
Jim_Paget Offline
The one post doesn't show up because it was deleted.
If you have a comment for a moderator we would prefer that you handle it with an email or a Private Message.
I can't help you with the part number for the rear drums. While we often use the term Speedbleeders generically, it is actually a specific brand name. The same type of device is sold under a number of names, e.g., Russel.
I would go to a "good" auto parts store and ask them to look up the part number for you.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: J. Paget RE: Speedbleeders........ #249735 03/06/03 05:29 PM
Jim_Paget Offline
I made a mistake the other day. In my hurrying through reading all the new threads on both the Talk and Tech side, I failed to notice that while there were posts regarding speed bleeders on both sides posted on the same day, they actually were from different readers.
Jim Paget
www.rrr4x4.com
Re: J. Paget RE: Speedbleeders........ #249736 03/06/03 08:07 PM
Thanks!!
Re: J. Paget RE: Speedbleeders........ #249737 09/09/07 12:11 AM
mceachrw Offline
98 Isuzu Rodeo - the ones listed below worked for me. The part numbers are for Russell speed bleeders sold at Summit Racing.
639570 - Front disc - more than 5mm longer than factory screw
639560 - Rear drum - perfect fit
Speed bleeder equivalents
SB7100 - Front disc
SB1010 - Rear drum
it looks like SB7100S would really be a better fit on the front. it is 30.22 vs 35.15 for the SB7100
i am about to order a SB8125 for the clutch slave cylinder. measurements look about right. i'll post back if it works.
PHP: 7.4.33 Page Time: 0.015s Queries: 14 (0.012s) Memory: 0.6052 MB (Peak: 0.6734 MB) Data Comp: Off Server Time: 2026-11-18 22:08:23 UTC
