No ground plane CB antenna #18747 05/07/03 02:33 PM
Kajo Offline OP
I need to buy a new CB antenna. I was going to buy a firestick II. After looking on the firestik website I found this:
http://www.firestik.com/Catalog/NGP_3-Way.htm
I have my antenna mounted on the rear corner of my 4Runner and figured this would solve the problem of not having a proper ground plane.
Anybody have any experience or opinions?
<small>[ May 07, 2003, 09:36 AM: Message edited by: Kajo4x4toy ]</small>
Re: No ground plane CB antenna #18748 05/07/03 04:48 PM
4Crawler Offline
I get a good ground and low SWR on my '85 4Runner:
CB Antenna Mount
Re: No ground plane CB antenna #18749 05/07/03 04:58 PM
A
AJ3 Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Kajo4x4toy:
<strong>I need to buy a new CB antenna. I was going to buy a firestick II. After looking on the firestik website I found this:
Anybody have any experience or opinions?</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">I just spoke with Bill's 2 Way about these and they are not a strong supporter of these ant. systems. Basically you will only get about 2 miles range. However, if it is only for trail rides it may work.
Art Jenkins
Gettin'Off4x4 Member
'92 xcab 4IFS,2BL, and tree bark paint.
Re: No ground plane CB antenna #18750 05/07/03 06:07 PM
fourwd1 Offline
John,
This is just another version of the old marine CB antenna, where the groundplane is created by a single counterpoise in the coax feedline. Better than no groundplane, but not much. The marine version at least uses a full quarter-wave (9') whip for max range/least loss.
Firestick is using inefficient 4', 3', and even 2' loaded whips. I wouldn't use a 2' or 3' antenna on a good groundplane (maybe a high quality 4' on a good groundplane, depending on circumstances). Rember, the shorter it is, the more loaded it is to accomplish this, and therefore more loss and narrower bandwidth.
If range is your objective, I'd try a coathanger first.
Broderick
<small>[ May 07, 2003, 01:12 PM: Message edited by: fourwd1 ]</small>
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: No ground plane CB antenna #18751 05/07/03 06:12 PM
4Crawler Offline
One thing to consider with the longer antennas is that if you do organized trail rides, they often have max. length limitations on antennas to prevent injuring folks on the side fo the trail (like spotters). For example Cal4Wheel has a 54" limit on most of their sponsored trips. This is why I run a 4' FireStik-II on my 4Runner. Between the antenna and base spring, I'm just under that limit.
Re: No ground plane CB antenna #18752 05/07/03 06:56 PM
Kajo Offline OP
AJ3- Thanks for the update. My 4runner is my daily driver so I would like as long of a range as possible.
Roger- My mount currently is in the same position as yours, just mounted a little differently. I used to run a full quarter wave on it but that was dangerous. I was running a 54" antenna that got ripped off by my garage door.
Broderick- I think if I wasn't a tech everything you said would have been over my head. I gotcha though.
I will be ordering a firestick II on line since nobody in the DC area seems to carry them. I would put a quarter wave back on except I remember the extreme wipping action on Kephart.
Re: No ground plane CB antenna #18753 05/07/03 07:02 PM
4Crawler Offline
Be sure to run a stiff base spring with the FS-II. The soft springs allow too much whipping and w/o a spring, the FS is too stiff and it will get damaged.
Re: No ground plane CB antenna #18754 05/07/03 09:25 PM
fourwd1 Offline
<strong>Broderick- I think if I wasn't a tech everything you said would have been over my head. I gotcha though. </strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">I thought it might cause you to recall some of the knowledge you gained studying for your license. <img border="0" title="" alt="[Wink]" src="images/icons/wink.gif" />
PHP: 7.4.33 Page Time: 0.007s Queries: 14 (0.004s) Memory: 0.6261 MB (Peak: 0.7250 MB) Data Comp: Off Server Time: 2026-06-07 05:17:48 UTC
