Hysteer, tire wobble, speed wobble problems #255739 05/16/01 10:01 PM
PARANOID56 Offline OP
ever since I have converted to hysteer i have had speed wables and a tire wobble problem. Every thing (tie rod ends, bearings etc..) all feel nice and tight. But while driving at around 25mph i get a little tire wobble. and at all speads i get like speed wobbles. So, i thought that i would adj my 9000 to the firmest setting, (usely they are at 1) the speed wables were not a bad, but had a tearble tire wable problem. When I look out the window while driving, i can see my tire moving a lot, back and forth. which in turn shakes the whole truck. <BR>It never did this when i had the old steering on it. After this, i put a steering stablizer on, and it helped a little, but still shake a little, i also put the shock back down to 1, so the terable shaking is mimamal. but the wheel still shakes back and forth. Anybody have any ideas.<BR>Thanks<BR>Shane<BR><P>------------------<BR><A HREF="http://home.off-road.com/~paranoid56" TARGET=_blank>PARANOIDS PAGES</A> "Of all the things I lost, I miss my mind the most."<P>1984 Toyota 4x4 SR5 X-Cab
PARANOIDS PAGES Of all the things I lost, I miss my mind the most.
1971 Toyota FJ40
2006 Subaru WRX wagon
Re: Hysteer, tire wobble, speed wobble problems #255740 05/16/01 10:07 PM
4Crawler Offline
<BLOCKQUOTE><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><HR>Originally posted by PARANOID56:<BR><B>ever since I have converted to hysteer i have had speed wables and a tire wobble problem. Every thing (tie rod ends, bearings etc..) all feel nice and tight. But while driving at around 25mph i get a little tire wobble. and at all speads i get like speed wobbles. So, i thought that i would adj my 9000 to the firmest setting, (usely they are at 1) the speed wables were not a bad, but had a tearble tire wable problem. When I look out the window while driving, i can see my tire moving a lot, back and forth. which in turn shakes the whole truck. <BR>It never did this when i had the old steering on it. After this, i put a steering stablizer on, and it helped a little, but still shake a little, i also put the shock back down to 1, so the terable shaking is mimamal. but the wheel still shakes back and forth. Anybody have any ideas.</B><HR></BLOCKQUOTE><P>Worn out spring and shackle bushings is my guess. I had the same identical problems, getting worse over the last few months. Could not feel anything loose until I disconnected the u-bolts and was amazed how much play I had in the front leaf springs, downright scary. New set of poly bushings and the steering was solid as a rock.<P>I had been running poly bushings but they were 3 years old and were just worn out.<P><P>------------------<BR>--<BR> Roger Brown<BR> 4crawler@home.com <BR> <A HREF="http://reality.sgi.com/rogerb/4Runner.html" TARGET=_blank>4Crawler Web page</A>
Re: Hysteer, tire wobble, speed wobble problems #255741 05/17/01 02:00 AM
What Roger said and you may also want to check the shims on the knuckles. With the axle and steering removed it should take about 10 lbs of force to turn each knuckle. If your knuckles are loose they will cause play in the front end. Did you reuse the shims from your old arms and put them on the new arms?
Re: Hysteer, tire wobble, speed wobble problems #255742 05/17/01 02:06 AM
Yea, i reused the shims that were in there. but the spring bushings do look warn. This weekend i will be putting in the new allpro drop hanger, and new longer allpro springs, with the new poly bushings. Hopefully it will help. Thanks<BR>Shane<P>------------------<BR><A HREF="http://home.off-road.com/~paranoid56" TARGET=_blank>PARANOIDS PAGES</A> "Of all the things I lost, I miss my mind the most."<P>1984 Toyota 4x4 SR5 X-Cab
1971 Toyota FJ40
Re: Hysteer, tire wobble, speed wobble problems #255743 05/17/01 02:17 AM
Also check your shackle bushings! Let me know if you need a set!
Re: Hysteer, tire wobble, speed wobble problems #255744 05/17/01 01:07 PM
OOP'S Offline
Make sure that your toe-in is set between 1/8-1/4"<P>------------------<BR>Maybe this world is another planet's Hell.<P>David Fritzsche, 1990 Ex-V-6, "NO-MO-IFS" otto@inreach.com<BR>http://www.geocities.com/solid_4x4/
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Hysteer, tire wobble, speed wobble problems #255745 05/17/01 07:20 PM
Shane,<BR>Have you checked your toe-in? My wheel shakes a little bit as well and I'm sure it's because I don't have enough toe-in and I'm at about 1/8". Marlin says that he usually shoots for around 1/4" with 33-35" tires and crossover steering. Just another thing to check.<BR><P>------------------<BR>Tim -- '84 Shortbed<BR> <A HREF="http://www.theworks.com/~fmfcr125/toyota/" TARGET=_blank>http://www.theworks.com/~fmfcr125/toyota/</A>
Re: Hysteer, tire wobble, speed wobble problems #255746 05/17/01 07:52 PM
I think my toe in is set at 0, so i will have to fix that this weekend, when i do the new springs. I never thought of that, i always thought that 0toe in was the best. less rolling resistance.<BR>Shane<P>------------------<BR><A HREF="http://home.off-road.com/~paranoid56" TARGET=_blank>PARANOIDS PAGES</A> "Of all the things I lost, I miss my mind the most."<P>1984 Toyota 4x4 SR5 X-Cab
1971 Toyota FJ40
Moderated by  4Crawler, 4x4Wire, Dandeman, kewlynx
PHP: 7.4.33 Page Time: 0.011s Queries: 14 (0.008s) Memory: 0.6179 MB (Peak: 0.7172 MB) Data Comp: Off Server Time: 2026-10-26 00:37:12 UTC
