here's the write up on my chevy 63" springs #19091 05/08/03 09:39 AM
RAZZMATAZ Offline OP
This spring swap is supposed to be an inexpensive alternative to aftermarket springs.. However with the u-bolt flip, extend shocks and shock mounts this could get a little pricey, especially if you have to pay someone to fabricate brackets and do the welding.
My rig rides nice....VERY NICE!!! This is my daily driver, I also use it to pull my boat over a 10,000 foot pass to and from a lake, so it has to be easy to drive! To tell you the truth I don’t think you’d notice much difference from the 225x75R15 and the stock suspension and what I’ve done to it other that the noise from the Super Swampers. One comment I got from Jeep owner was. “Wow, this thing drives like my brothers new Silverado”.. To me that’s a bit of a stretch but you get the idea..
I purchased the springs from a local junk yard for $35 for the pair ( thanks Fabian). I fabbed up the front hanger brackets from a piece of 3¢"x3¢" square tubing. I mounted them 11" CTC from the old hanger. I wish I would have mounted them 11¢" or 12" because when stuffed there is a large gap between front of the tire and the fender and they almost rub the back of the fender. <img src="http://www.geocities.com/razzmataz300/frontspmt.txt" alt=" - " />
Rear shackles were made from 1¢"x9"x3/8" pieces of steel with the holes mounted 7¢" CTC <img src="http://www.geocities.com/razzmataz300/shackle.txt" alt=" - " />
The U-bolt flip was made using 5/8" U-bolts 3"x8¢", and the plate are out of 5¢"x6"x¢".
<img src="http://www.geocities.com/razzmataz300/uboltplate.txt" alt=" - " />
Check out my upper shock mount! it&#8217;s a 2"x2"x41?" piece of squar tube 1/8" thick.. With my 2" body lift I just welded it to the top of the frame rails 29¥" from the back of the frame. the shocks are Rancho RS9000X PN RS99012 .. Thes shock are 32.250" when fully extended and 19.375" when compressed, they have 1 5/16" wide bushings with 5/8" holes on both ends. <img src="http://www.geocities.com/razzmataz300/upshmount.txt" alt=" - " /> <img src="http://www.geocities.com/razzmataz300/upshock3.txt" alt=" - " /> <img src="http://www.geocities.com/razzmataz300/shocks.txt" alt=" - " />
Lower shock mounts are from AOR. they are mounted 11" inboard from the flange that the brake backing plate bolts to. I have an idea that would elimanate having to use weld-on brackets and use more of the 12.875" inches of travle that these shocks offer. <img src="http://www.geocities.com/razzmataz300/lwrshmt.txt" alt=" - " />
In order for the parking brake cable to clear I had to move this bracket about 2¢" CTC towards the front of the truck. The bracket was made from 1 1/8"x5¢"x1/8" strap. <img src="http://www.geocities.com/razzmataz300/prkbrk.txt" alt=" - " />
I ended up ussing a 5? shim(thicker end towards the front) betwen the axle perch and spring. This will eventually come out and the perch will be rewelded on the axle tube to give me the same pinion angle.. As for now it IS vibration free.
If any of you guys need some of these parts or a complet &#8220;kit&#8221; fabbed shoot me an email. I can turn most of this stuff out in a day or two..
Be Wild,
RAZZ
87 4Runner 22R-TE
4 Pro Comp IFS
63 Chevy springs
5.71 gears
Detroit in rear, Lockright in front
35 MT/R
Rancho 9000
Jacobs ProStreet ign module and Ultra coil
1992 3VZ-E swapped in
Re: here's the write up on my chevy 63" springs #19092 05/08/03 12:25 PM
Thank you guess you know what i will be doing Off to the metal shop i go <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
Re: here's the write up on my chevy 63" springs #19093 05/08/03 03:18 PM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans"> I have an idea that would elimanate having to use weld-on brackets and use more of the 12.875" inches of travle that these shocks offer. </font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">What is your idea? I was thinking the ones at RockStomper would be good, since they move the lower shock mounts outward (toward the wheels).
Ryan
Re: here's the write up on my chevy 63" springs #19094 05/08/03 11:36 PM
Lou Bell Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Lou Bell:
<strong>I have read that with a dual rear shackle set-up, the rear driveshaft is too short (not so with the single rear shackle). Could you verify this for us?
Also, I think a kit would be a great idea. <img border="0" title="" alt="[Cool]" src="images/icons/cool.gif" /> Especially if you sell the pieces individually or together. Start coming up with some pricing and post it (or a link to it). That way you can ride the wave of interest that you helped to create.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">
'87 4runner 37x12.50x15 MTRs
SAS, 4.88's, rear+front e-lockers
4x4Him --- Christian 'wheelin
4x4Him National Forum
Re: here's the write up on my chevy 63" springs #19095 05/09/03 12:46 AM
<strong> </font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Lou Bell:
Also, I think a kit would be a great idea. <img border="0" title="" alt="[Cool]" src="images/icons/cool.gif" /> Especially if you sell the pieces individually or together. Start coming up with some pricing and post it (or a link to it). That way you can ride the wave of interest that you helped to create.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans"></strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">I still use the stock drive shaft I'll have to flex it again and take a look to see if it's about to come out when it's tweeked.. I'll get back with you guys on that.
I post some prices for the parts/kit later tonight..
Cheers,
RAZZ
87 4Runner 22R-TE
4 Pro Comp IFS
63 Chevy springs
5.71 gears
35 MT/R
Rancho 9000
Re: here's the write up on my chevy 63" springs #19096 05/09/03 02:26 AM
ok wait that looks way too simple.. someone educate me.
do i need to move the shock mounts on my rig? i know it would be much more useful but do i NEED to?
so all i need to really do to have them mounted is cut a few pieces of steel 1x11in make two holes almost like an extension shackle to connect to the shackle?? no work needs to be done on front of leaf or rear with 11in piece?
along with ubolt flip kit and ebrake fix. that's all right?
Re: here's the write up on my chevy 63" springs #19097 05/09/03 02:29 AM
ah sorry, ignore the second question in my last post, all i need to know is the shock mount q. ahh what can i say i'm 19 i don't read many directions i just look at the pretty pics and open my mount <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" /> !
Re: here's the write up on my chevy 63" springs #19098 05/09/03 03:20 AM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by RAZZMATAZ:
<strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans"></strong>[/QUOTE]I still use the stock drive shaft I'll have to flex it again and take a look to see if it's about to come out when it's tweeked.. I'll get back with you guys on that.
Cheers,
RAZZ[/QB][/QUOTE]
most people don't think about this when they are checking to see if their shaft is too long or not long enough.they just flex it up and say it looks good and will do.but if it looks like it is close to comming out of the rear by lets say 1.5" or 2",most people say thats good. but what they usually dont think about is, what happens if the whole rearend jumps in the air or the whole rearend completely falls down( let's just say your wheelhopping) and when you measured,only one side was dropped and the other was up,not to mention the shaft is in the middle. i always jack the truck until it is almost completely off the ground,then compress it with a big ratchet strap or something..to me that just gives it a better idea of what ya need..just my $.1/2 of thought <img border="0" title="" alt="[Smile]" src="images/icons/smile.gif" />
Re: here's the write up on my chevy 63" springs #19099 05/09/03 05:14 AM
I was just wondering how much flex you get with those Rancho 9000s? What is the length of those shocks extended and collapsed? I did the chevy swap on my truck too and I was thinking of putting in some Rancho 9012s. Let me know. Thanks.
Re: here's the write up on my chevy 63" springs #19100 05/12/03 06:36 PM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Sprung85:
<strong>I was just wondering how much flex you get with those Rancho 9000s? What is the length of those shocks extended and collapsed? I did the chevy swap on my truck too and I was thinking of putting in some Rancho 9012s. Let me know. Thanks.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">According to the Rancho web-site they are 32.250" extended and 19.375" colapsed.. that gives the shocks 12.875" of travel.
RAZZ
87 4Runner 22R-TE
4 Pro Comp IFS
63 Chevy springs
5.71 gears
35 MT/R
Rancho 9000
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.009s) Memory: 0.6356 MB (Peak: 0.7592 MB) Data Comp: Off Server Time: 2026-11-18 03:44:26 UTC
