Question regarding OME spring sag #260105 05/07/02 08:50 PM
Aurora Sandman Offline OP
As some of you read from earlier posts, I got an Old Man Emu spring and shock setup last month:
Disappointed with OME lift -- in need of advice
FOLLOW UP: How my OME installation finally turned out...
After a month, and a couple of trail runs, the lift has sagged:
Front: heavy duty 881 springs, originally 2" lift, now 1.25"
Rear: medium duty 890 springs, originally 3" lift, now 2.75"
I am thinking of getting cornfed 1.0" spacers to bring to up the front.
My question is, how long did it take for the sag on your OME springs to stabalize? Should I go ahead and get spacers now, or wait a little longer to see if I get additional sag?
Mike
<small>[ 07 May 2002, 04:03 PM: Message edited by: Aurora Sandman ]</small>
Mike Brown, 2001 4Runner, 4.88 gears, ARB rear locker, OME springs (heavy duty with two 5mm packers/spacers on each side in front, medium duty rear), OME comfort shocks all around, 33x10.5 BFG Mud Terrains, Slee Offroad sliders, & deck plate mod
Re: Question regarding OME spring sag #260106 05/07/02 09:21 PM
My took about 1 month but I didn't put in the spacers till about 6 mos later. If I were you just go with the 1" that way your CV's will be ok.
dave
Re: Question regarding OME spring sag #260107 05/07/02 10:33 PM
OME customers are Cornbreds customers. He's got a big batch right now, it's a good time to order.
Re: Question regarding OME spring sag #260108 05/08/02 01:34 AM
By putting spacers on progressive springs, aren't you affecting the shocks/springs rebound capabilites?
I installed my OME's (regulars)last month. I have an 1.25 fronts and 2.75 rears for lift. Haven't seen any sagging as of yet.
Id like to level it off as well.
<small>[ 07 May 2002, 08:39 PM: Message edited by: smr4runner ]</small>
Re: Question regarding OME spring sag #260109 05/08/02 03:00 AM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by smr4runner:
<strong>By putting spacers on progressive springs, aren't you affecting the shocks/springs rebound capabilites?
Id like to level it off as well.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">The Front OME springs are NOT progressive the rears are. PP front springs and TRD Tacoma front springs are progressive.
Not the front OME's
Re: Question regarding OME spring sag #260110 05/08/02 04:23 AM
Ah, Thanks Steve.
With adding 1 inch spacers how much of an affect would it have with rebound capabilities..etc?
Re: Question regarding OME spring sag #260111 05/08/02 04:29 AM
<strong>Ah, Thanks Steve.
With adding 1 inch spacers how much of an affect would it have with rebound capabilities..etc?</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">A 1" Cornbred would stiffen up the springs a hair. You will also get the same amount of lift with stock front springs and a 2" Cornbred.
I really don't think it would effect much, my stock springs still handle the same.
This spacer is tried and true, the others are not.
Re: Question regarding OME spring sag #260112 05/08/02 05:16 AM
<strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">A 1" Cornbred would stiffen up the springs a hair. You will also get the same amount of lift with stock front springs and a 2" Cornbred.
This spacer is tried and true, the others are not.</strong>[/QUOTE]
Thanks Steve. This may be the route I go then.
Hey Mike. You have me worried now. You say you dropped .75 with the 881's.
Im going to have to keep a close eye on my 880's. If I notice any sag I'll return the front OME'S, stick my stock springs and 2inch cornfed spacers in there. Problem solved.
I'll be talking to ARB tomorrow to see what they have to say about this issue.
I'll let you know.[/QB][/QUOTE]
Re: Question regarding OME spring sag #260113 05/08/02 05:57 AM
man i'd like to know what ARB has to say also regarding this issue, seeing that I JUST ORDERED the HD Springs and Shocks this morning! Got me kinda worried now....... <img border="0" title="" alt="[Eek!]" src="images/icons/shocked.gif" />
Re: Question regarding OME spring sag #260114 05/08/02 06:17 AM
Jeff the marmot Offline
Looks like my OME HD rear springs have sagged 0.5" over one year. I'm planning on a spacer pretty soon.
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
Moderated by  4Crawler, 4x4Wire, Dandeman, kewlynx
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6221 MB (Peak: 0.7431 MB) Data Comp: Off Server Time: 2026-06-23 14:15:36 UTC
