strange idle when depressing brake #19629 03/04/02 07:18 PM
Mean__Gene Offline OP
hello,<P>recently my idle has become very funky... the cold idle is about 1900rpm or so, and as the engine warms, it comes down to about 1200rpms.... except when i have the brake depressed, then the idle bounces from 1200 - 600-800rpm.. it bounces up and down like a rubber ball... probably like once every 5 seconds. i'm guessing it has something to do with the vacuum necessary to work the brake booster, and perhaps something is wrong with the booster and it is leaking air inside or something [unfortunately i've never seen the insides of a brake booster...]<P>any ideas?<P>thanks.gene.
Your ad here.
Re: strange idle when depressing brake #19630 03/04/02 07:48 PM
Does it do this when it's cold or warmed up?<P>RK [img]images/icons/shocked.gif" border="0[/img]
Re: strange idle when depressing brake #19631 03/04/02 09:11 PM
Kendall Offline
I had the same problem on my 88. I cleaned the intake at the throttle plate and it seemed to have fixed it. Have not had the problem since.
88 Xtra Cab, SAS, 35X12.50 MTR, Toyota E-Lockers front and rear, Rear seat, custom nerfs and rear bumper.
Re: strange idle when depressing brake #19632 03/04/02 10:26 PM
I've heard of this before. Shawn F from the ORC board wrote about it on his site.<BR> <A HREF="http://www.geocities.com/toyotashawn/bizzareidle.html" TARGET=_blank>http://www.geocities.com/toyotashawn/bizzareidle.html</A> <P>It's a long article, otherwise I'd post it.
Re: strange idle when depressing brake #19633 03/05/02 01:51 AM
My 85 22re did this a few years ago.<BR>This may bear no relation to your V6 problem, but I'll throw it out here anyways.<P> In my case there was a plastic one-way valve in the vacuum line running along the top of the fire wall over to the brake booster. This valve had taken a dump and was causing the cyclic rise and fall when the brakes were on while sitting at a stop. A new valve was a few bucks at the dealer and was simply a matter of removing the old one and slipping the new one onto the vacuum line.
Re: strange idle when depressing brake #19634 03/05/02 03:51 AM
More than likely your idle is set too high. Set the idle at the factory spec or slightly above when the engine is warm and it should go away. My 22re will do this when the idle gets above about 1100rpm, factory is about 800. I set mine at about 1000 to help when crawling.
Re: strange idle when depressing brake #19635 03/05/02 10:00 PM
<BLOCKQUOTE><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><HR>Originally posted by pmurf1:<BR><STRONG>More than likely your idle is set too high. Set the idle at the factory spec or slightly above when the engine is warm and it should go away. My 22re will do this when the idle gets above about 1100rpm, factory is about 800. I set mine at about 1000 to help when crawling.</STRONG><HR></BLOCKQUOTE><P>really? hmmm.. well, since this would be the most simple solution, i'll try it first... that's weird how my idle could get all outta whack for no reason... i mean, it ran perfect until a few weeks ago when this braking-fluctuation started... what could cause an idle speed to suddenly jump so high?<P>thanks.gene
Your ad here.
Re: strange idle when depressing brake #19636 03/06/02 05:54 PM
ErikB Offline
Toyota Moderator
<BLOCKQUOTE><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><HR>Originally posted by pmurf1:<BR><STRONG>More than likely your idle is set too high. Set the idle at the factory spec or slightly above when the engine is warm and it should go away. My 22re will do this when the idle gets above about 1100rpm, factory is about 800. I set mine at about 1000 to help when crawling.</STRONG><HR></BLOCKQUOTE><P>I think pmurf nailed it. 22RE's will do this if the idle is too high. Same thing happens if the A/C idle-up is set too high.
http://home.4x4wire.com/erik
Re: strange idle when depressing brake #19637 03/06/02 10:36 PM
erased post
<small>[ 20 March 2002, 03:06 PM: Message edited by: Mean__Gene ]</small>
Your ad here.
Re: strange idle when depressing brake #19638 03/20/02 09:06 PM
alright, it's been about a week after adjusting the idle down, and amazingly enough, that seems to have fixed the problem. i'm not sure what initially caused the idle to jump nearly 1000 rpm in the time of about 2 weeks, but it seems fixed now..
thanks to everyone who helped me!
later.gene.
Your ad here.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6285 MB (Peak: 0.7496 MB) Data Comp: Off Server Time: 2026-06-21 16:10:33 UTC
