advice on cj7 frame-up rebuild #275846 04/10/03 02:57 AM
mwhite Offline OP
I have a 83 cj with a 258,tf999,dana300,a/c,amc20,
dana30. 31inch buckshots soon to have 33s
I am planning on having the frame powder coated(my son has
his own powder coating bus. so its free) raplace all busshings
with poly ones, add a 1 inch poly body lift. a 2 1/2 spring lift
durabak the inside of tub and under tub and all fenders
also the inside of the hardtop.
I am planning on swapping the engine next year either
a 4.0 or a chevy 4.3 with a 700r.,
what will I run into on dissasembly any tricks of the trade?
thanks for any advice
Mike
<small>[ April 09, 2003, 09:59 PM: Message edited by: mwhite ]</small>
88 Mighty Max 2.6 (170,000miles)
3 body lift, 1 1/2 torsion lift, lower bumpstops, 4.625
gears, 31 1/2 buckshot radials,warn 8274
Re: advice on cj7 frame-up rebuild #275847 04/11/03 08:36 PM
Well Id change a few things. Im going through a frame up on an 81 CJ5 right now, its a bear.
First instead of Powder coat on frame POR 15 it. You wont chip/scratch POR15 and you will NEVER worry about rust.
http://www.por15.com/
I take it Durabak is simalar to Speed/Rhino liner? Im using POR15 on my underbody as well, Will Speedline the interior tub.
Why a body lift at all? why not 3-4 Inch suspension lift?
Only trick I can say is have SEVERAL cans of PB blaster on hand as well as tons of baggies for small parts that you can label. I will be replacing every single TORX bolt on this thing. If you can get rid of them do it as well.
Careful with the tub bolts, I know too many folks that ended up having to cut them out use a ton of PB on them.
Id worry about running 33's on stock AMC20 and Dana 30's at least look into a 1 piece axles, you may need to regear as well. I havent even crossed that bridge, was running 31's and cant decide if Im going 32 or swap axles and go 33's.
Good luck, post some pics of your progress.
Dave
Re: advice on cj7 frame-up rebuild #275848 04/11/03 09:57 PM
Damon Dimick Offline
First off, let me say that I really like how you're doing your buildup. It sounds like a truly balanced set-up, good components, light, reliable, and done right the first time. I'm in the middle of my 85 CJ-7 project as well, and disassembled the rig down to parts last summer.
As Dave said, make sure and hit as many bolts as possible with PB Blaster, as often as you can the week prior to disassembly. Also, buy some air tools if you haven't already. For the money spent, they are the best purchase I've ever made. Between the Blaster and the air tools, I didn't break a single bolt in the entire teardown.
Spend a lot of time labeling and bagging bolts and pieces, it's a pain when you're in the middle of it, but invaluable later down the line.
Removing the computer/wiring harness on the pass. side firewall can be a pain if you don't disassemble some of the heating assembly, but can be done without.
If you're going to run 33's and will need to re-gear anyway, look at buying a Scout II rear Dana 44 at the same time. You can pick them up for under $150 usually, they have the same bolt pattern, and are only a couple of inches wider than the stock widetrack AMC 20. All you'll have to do is move spring perches and shock mounts. Compared to buying the mandatory one piece shafts for the 20, or adding an axle truss, just buy the 44 and be done with it. 33's will be fine on the front Dana 30...it's really a pretty strong axle.
I was on the fence between powder coating and POR-15, but have since decided to do the POR. Mainly because I like the ability to grind/weld and touch up the frame, which just can't be done with powdercoating. Also, I've heard powdercoating won't show stress cracks in the frame very well, which is a common problem on CJ's around the motor and spring mounts. But if it's free, and you don't plan on modifying/welding too much in the future, I'd say powdercoating would be pretty ideal. See if your son can do something about the inside of the frame while he's at it...that would be nice.
Look into adding a clocking ring to your 300 when you add the trans; rotate that baby up and out of the way. If you want to rotate it all the way up to run a perfectly flat skid-plate (cool <img border="0" title="" alt="[Cool]" src="images/icons/cool.gif" /> ), you'll have to cut a pretty small patch in the floor, but once you line the tub, it'll look pretty unnoticable. Especially with 33's and only a few inches of lift, the Dana 300 will really soak up a lot of valuable clearance under your Jeep.
Anyway, keep us updated on the project, it sounds like it'll be really nice.
51 CJ-3a, 78 Cherokee Chief
Re: advice on cj7 frame-up rebuild #275849 04/12/03 03:59 PM
How tough is this POR-15 stuff? Their site says it won't "chip, crack, or peel", but can it be burned off by heat from the exhaust? My powder coated bumper has a spot that rusted because it was getting hit by exhaust from the tailpipe. Would the POR-15 stand up to something like that?
Re: advice on cj7 frame-up rebuild #275850 04/14/03 04:32 PM
As far as Ive seen POR 15 will not be effected by heat. I know folks who have had it for years on undersides of Jeeps and Street Rods and have seen NO sign of heat affetcing it.
The only weakness of POR15 is UV light. Thats why its only used for underbody. You can use it for a base coat/primer if you top coat it.
I plan on Using POR on my entire underbody Frame/tub Fenderwells and then as a base coat for interior of tub that will be covered with Speedliner for UV protection.
It gets expensive, at 95$ a gallon, not to mention the prep chemicals needed for proper application. But since I'm going the extra mile on my Restoration and putting some serious money into this project (been working on it for a year and will be another year min to be done) the cost of POR 15 doesnt bother me.
I want the Jeep tip top show condition as well as serious trail rig when im finished.
BTW anyone know where to get ready made dana 44's front and rear narrow track with solid axles and lockers? Id rather have them built and ready to go than hit junkyards and rebuild them.
Re: advice on cj7 frame-up rebuild #275851 04/14/03 11:54 PM
mwhite Offline OP
Davefl, The reason I am putting the lining on the
underside of tub and wheelwells is for sound and insulation
and with Louisianna Gumbo mud it cleans up really well.
I have the body off now no real problems doing it.
I do have air tools and a friend who has done one before.
The frame is now at my son's shop being sandblasted.
still not sure what to do (powder coat or paint or por15)
the frame is 20 years old and was in pretty good shape.
The reason I was thinking of the 1" poly body lift was to clock
the d300 up as high as possible without cuttung floor.
Thanks for all replies
Re: advice on cj7 frame-up rebuild #275852 04/15/03 04:21 PM
Okay never thought about sound insulation from under the tub, I know it slightly reduces sound when on the inside of the tub.
I don't know how well the stuff takes heat, so be warry around the exhaust. And your right about cleaning up well, I thats why I want my tub lined with it so I can more or less spray it out.
The body lift will work for what you are doing, I dislike body lifts in general but 1" is the max I would go.
I still say POR the frame, Although the powder coat is free, which is great. POR15 is an investment for rust prevention.
Good luck, I think your project will be done way before mine. Lets see some pics as it comes along.
Dave
PHP: 7.4.33 Page Time: 0.015s Queries: 14 (0.012s) Memory: 0.6137 MB (Peak: 0.7106 MB) Data Comp: Off Server Time: 2026-11-18 12:00:25 UTC
