CJ7 motor swap to 4.0 Help
#276228
04/26/03 04:07 PM
I found a 4.0 for $500.00 with wiring harness and ECU. It has a cable for the auto kickdown, I have a linkage for my kickdown for the TF999, will the cable bolt on or do I need a adapter? I know I need to purchase a flywheel sensor Kit, do I need anything else?
88 Mighty Max 2.6 (170,000miles) 3 body lift, 1 1/2 torsion lift, lower bumpstops, 4.625 gears, 31 1/2 buckshot radials,warn 8274
Re: CJ7 motor swap to 4.0 Help
#276229
04/27/03 05:47 AM
I've heard there is an aftermarket cable kick down for the 999. Probably Lokar sells some generic kick down you could use.
As to what else you might need, I can't think of anything, but there are probably lots of little things you will need to complete the job.
#276230
04/27/03 04:26 PM
Mwhite,
I modified my throttle linkage, by using both the linkage assemble from the 4.0 and my 4.2 I have yet to get the vehicle running but it seems to work. if your interested I will take a picture of the modification. I also have a three inch body lift on my jeep the egr transducer was touching the steering shaft. I bought a one inch motor lift mounts from MORE. I aslo purchased a external fuel pump for a 89 ford f100 for 62 bucks along with a filter.
Good luck
<img border="0" alt="[Chicken]" title="" src="graemlins/chicken.gif" />
#276231
04/28/03 04:39 AM
Guys, I'm doing the same swap. I bought a vss to mechanical speedo assembly from hesco along with the hamonic balancer kit.
Hey Mkrapf, how does that ford fuel pump work, any special mods to make it work?? What size are the fuel lines??
Thanks, Ben
#276232
04/29/03 04:46 AM
benc, I have yet to attach the ford fuel pump, but it looks like 5/16 inch connections. I am going to use 5/16 high pressure lines with barbed brass fitings that I bought at the hardware store. I need to pick up a 1.5 inch pipe clamp at the local home depot and should be good to go. I will also add the balance resistor. that goes with the jeep computer.
PHP: 7.4.33 Page Time: 0.012s Queries: 14 (0.009s) Memory: 0.5958 MB (Peak: 0.6590 MB) Data Comp: Off Server Time: 2026-11-18 03:20:13 UTCValid HTML 5 and Valid CSS
