4 banger power #277040 05/27/03 05:53 AM
Flouris Offline OP
I have an 89 YJ with a 4 banger, and I am having trouble figuring out what I can do to get some more power. I am running 31" tires so i notice a bit of power loss, especially in the upper gears. I plan to put on a cat back exhaust system. Besides that what else can I do? Rock it makes aftermarket intakes, throttle bodies and spacers for the 2.5L, but not for my 89. I checked headers, but I am having a hard time finding those for my car as well. ANY ideas/tips would be much appreciated...Thanks
'95 Wrangler, 4.0L, Rock-it Air Intake, tornado, Performance Distributors Ignition kit, 31's, 2.5" Pro Comp Suspension lift, Hella fogs, Light Bar
Re: 4 banger power #277041 05/27/03 06:18 AM
http://www.cris.com/~jman/jeepmods.html
This works on pretty much any inline jeep engine... try it out
Re: 4 banger power #277042 05/27/03 06:19 AM
erm, fuel injected inlines that is....
Re: 4 banger power #277043 05/27/03 08:15 AM
Um, all YJ 2.5L's are EFI. Earlier ones are TBI though. Personally, I found no gain what so ever when I removed those so called restrictors. The one in the airbox is more of a venturi which causes a vacuum that pulls the crank case fumes back into the engine.
Cat-back exhaust, headers, K&N conical filter, +8mm spark plug wires... Lots of stuff to consider. But you won't be able to do a 4.0L TB since you have TBI. You might be able to do a .450 duration cam. Hard to find the .440's anymore.
Re: 4 banger power #277044 05/28/03 12:27 AM
Flouris Offline OP
To put in a conical K&N air filter what do you suggest I do since there is no replacement air tubes that I can find for the 89...everything is 91-95.
Re: 4 banger power #277045 05/28/03 05:38 AM
Borla makes headers for the 89 2.5L. I put them on my 89 YJ and i love 'em. that EGR valve is nasty, though. I had to take it to the muffler shop and have 'em bend it. I also put in a K&N panel filter and i noticed a difference.
This weekend I just got done with removing the mechanical fan and putting in an electric and i've noticed a little difference.
it's all step by step.
Re: 4 banger power #277046 06/01/03 07:23 AM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Flouris:
<strong>To put in a conical K&N air filter what do you suggest I do since there is no replacement air tubes that I can find for the 89...everything is 91-95.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Well, you might be able to use one for a 91+. SOme guy's are using Honda Civic air tubes on their Jeeps. Since I wanted one way before there was even a market, I custom built one. You might have to resort to a custom one. You could even use black ABC tubes to make one.
Re: 4 banger power #277047 06/05/03 02:00 PM
superdawg Offline
What axle gears did you change to when you went with the bigger than stock size tires?
SD
Re: 4 banger power #277048 06/10/03 05:39 AM
Flouris Offline OP
I actually didn't change any gearing on my truck...my tires are not massively oversized...only 31" but i noticed a small differnece in acceleration and power.
Re: 4 banger power #277049 06/11/03 08:13 AM
31's are about the limit on a 2.5L manual before you start to feel a loss in performance. I ran 32's for several years with stock gears. You probably won't need too much to regain the power you lost. After driving around with 32's, I thought 31's felt stock. I'd go with the basic's. Decent exhaust, perhaps performance cat, conical air filter. Maybe even an electric fan. By moving the fan to a dedicated electric motor, it leaves the engine to power the Jeep.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6253 MB (Peak: 0.7462 MB) Data Comp: Off Server Time: 2026-06-20 18:33:41 UTC
