Rs3000 "brain" #285178 07/12/03 06:06 PM
P
Postal Bill Offline OP
Can anyone tell me how to get to the alarm brain on a 2001 Tundra? I was able to get to the glass breakage sensor control, but can't see the main control unit (ECU). Its supposed to be on the left under the dash? <img src="/forums/images/graemlins/confused.gif" alt="" />
Growing OLD is mandatory
Growing UP is optional
2001 Tundra
2001 4 Runner
1984 Corvette
Re: Rs3000 "brain" [Re: Postal Bill] #285179 07/12/03 10:17 PM
ErikB Offline
Toyota Moderator
How about under the drivers seat? Just a guess...
http://home.4x4wire.com/erik
Re: Rs3000 "brain" [Re: ErikB] #285180 07/13/03 01:08 PM
P
It is not under the seat. Toyota service said under dash on left side, but wouldn't tell me what all I had to remove to get to it. I removed lower part of dash, under sterring wheel, but could not locate it <img src="/forums/images/graemlins/mad.gif" alt="" />
2001 Tundra
2001 4 Runner
1984 Corvette
Re: Rs3000 "brain" [Re: Postal Bill] #285181 07/13/03 05:20 PM
ErikB Offline
Toyota Moderator
Maybe under the kick-panel then? On my truck I think the cruise control brain is there and a fuse panel.
Otherwise maybe take your truck to the stealer for an oil change and while you're there grab one of the techs and make them show you exactly where its at... <img src="/forums/images/graemlins/wink.gif" alt="" />
FWIW, I'd bet its somewhere that is fairly easy to get to since it is optional equipment that has to be installed at the dealership.
Re: Rs3000 "brain" [Re: ErikB] #285182 07/13/03 10:02 PM
surlynkid Offline
dealership or PIO??
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Rs3000 "brain" [Re: surlynkid] #285183 07/14/03 09:01 PM
P
I found it! It is up under the dash to the right and above the steering wheel shaft. (Wrapped in gray sponge- [color:"black"] [/color] foam) You have to take the bottom panel of the dash off, 4 bolts, and pull out the air duct. Pretty easy when you know where it is. [color:"blue"] [/color]
2001 Tundra
2001 4 Runner
1984 Corvette
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6095 MB (Peak: 0.6795 MB) Data Comp: Off Server Time: 2026-06-17 08:02:27 UTC
