Clutch master cylinder rebuild????'s #286065 07/14/03 05:49 PM
rattler98 Offline OP
I need to rebuild my clutch master cylinder today (92', 3.1L, 4x2 with T-45 BW transmission) and I wanted to know what is involved in this procedure. I havenÆt looked at my Haines manual yet, but maybe someone could let me know the answers to a few questions.
#1 Is it necessary to remove the master cylinder from the truck in order to rebuild the unit?
#2 Do I need to mark the rod on the clutch pedal so that I can put it back it in the same place after reinstallation?
#3 Is there a bleeder valve, or some other way to bleed the line once itÆs back together?
#4 Are there any ôwhatever you do, donÆt do this!!!ö things that I need to know?
As always, the help is appreciated!!!
1992 Isuzu Rodeo, newly rebuilt 3.1L v6 and rear diff; clear corners, bumper and tails; Aiwa MP3 head unit; Infinity Perfect 10.1 sub; Polk seperates; Sony cross and amps.
Next projects -- New paint, tint, billet grill, nerf bars.
Re: Clutch master cylinder rebuild????'s [Re: rattler98] #286066 07/14/03 06:23 PM
RobG Offline
Yes
No
Should be. My setup is different, so i can't tell you exactly, but it should be somewhere at the highest point on the lines.
Not that i'm aware of, but i always used reman'd units rather than rebuilding them myself.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 38x13 TSLs, spooled D60 front, 14bff rear locked by detriot, high steer w/ hydro, dual Isuzu tcases.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5880 MB (Peak: 0.6363 MB) Data Comp: Off Server Time: 2026-06-25 00:51:37 UTC
