Water temp. sensor mod.. didn't work #288617 07/19/03 11:15 PM
E
Eck Offline OP
I tried the sensor mod today to get the motor run a bit richer. It was so rich it wouldn't even start after it stalled the first time. 500 Ohm resistor into the water temp. sensor plug. Pulled the EFI fuse, etc... The truck started but coughed quite a bit and idled at 1500rpm. Step on the gas and it would stall immediately. Truck was cold but outside temp around 100 and climbing. I tried taking it for a drive but coudn't even get out of the driveway. So I put everything back to normal. Runs like before.
Does anybody have experience with this mod? Dr.Z's write up was done with a 500 Ohm pot. Shouldn't be any different.
Any ideas are welcome,
Thanks,
Eck
92 Xcab V6 4x4 SR5 5sp., Detroit locker rear, lim. slip front, Warn hubs, H4's, electr. fan, eng. oil cooler, 1 lift, open cat.
Re: Water temp. sensor mod.. didn't work [Re: Eck] #288618 07/19/03 11:31 PM
What engine, if 22re I have a 5000 ohm pot not 500 ohm. Thats a big difference. Do a search I wrote up on exactly how to do it in a previous post. Hope that helps
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.5843 MB (Peak: 0.6338 MB) Data Comp: Off Server Time: 2026-07-17 07:52:14 UTC
