interior brake noises ? #291299 07/24/03 11:18 PM
rh71 Offline OP
What does it mean when, after driving a lot of stop-and-go for a bit, pressing the brake results in a "creaking" noise ? Am I low on some fluid or something ? The sound is coming from the brake pedal area itself.
http://www.rh71.com
/misc/rodeo.jpg
Re: interior brake noises ? [Re: rh71] #291300 07/25/03 05:44 AM
CPOM Offline
You might get a high-pitched noise when the wear-indicator reaches the rotor, as in "go buy more pads". But usually, this noise is heard without breaking, and goes away when the pedal is depressed.
oh, I just read your post again, you're talking about that creaking noise literally near the pedal? As you push it?
That could be coming from your master cylinder seals, maybe. Hopefully someone else knows, just keep an eye on the fluid level til you find out.
CHRIS
98 Amigo, 92 Pup
Re: interior brake noises ? [Re: CPOM] #291301 07/25/03 05:51 AM
i think he's referring to a more groaning-like noise, from when u lightly apply and release the pedal, for instance u are facing down a hill and slightly let your foot off the pedal and u slowly begin to creep down the hill all the while your brakes are groaning really loud inside the truck, i've always wondered about that too, it never really worried me though, since i changed my brakes these crappy pads do it all the time <img src="/forums/images/graemlins/angry.gif" alt="" />
Re: interior brake noises ? [Re: rh71] #291302 07/25/03 07:00 AM
Joelpat Offline
Can't help with your question, but I have a related one.
My trooper has always (for the last 10 years) squealed and groaned when the brakes are applied while the vehicle is traveling backwards.
I was under the impression this is a characteristic of 1st gen troopers. Anyone else have this?
-Joel
'02 Trooper S
The dog-mobile.
'90 Trooper LS
Dearly departed after 13 years in the family. Donated to WAMU Radio in DC.
Re: interior brake noises ? [Re: Joelpat] #291303 07/25/03 07:20 AM
Ed Mc Offline
The factory pad set helps with the moanin' and groanin'
Get a set from St. Charles Isuzu and shut them rear brakes up! <img src="/forums/images/graemlins/ignore.gif" alt="" />
'90 Troop 3.4 LS
'89 Troop RS (Has Valve Issues, needs Counseling)
HI, I'm Ed and I'm a Trooper-holic!
Keep On Troopin'......
Re: interior brake noises ? [Re: Joelpat] #291304 07/25/03 07:46 AM
Yep, mine do the same thing. I assumed it was due to cheap pads and no anti-squeal applied to the back at the last change.
For the groaning I have no good answer except I've heard that type of noise in many different vehicles. Could be the pads chattering on the rotors just a little, noises like that have a weired way of traveling through the vehicle and getting amplified. If the noise is coming directly from the brake pedal area you could try applying some type of grease or other lubricant to all the pivot points.
Re: interior brake noises ? [Re: Ed Mc] #291305 07/25/03 12:04 PM
troopinstile Offline
Yepper, I had the same problem four years ago when I bought my 90, you need a set of pads for a 1991 (yes that's right 91 no matter what year your Troooper is) for a PICKUP( thats right again, a pick up) it's something in the composition of the pad, and it works, and best yet, they've been on there for about 50,000 miles, and still going strong! <img src="/forums/images/graemlins/cheers.gif" alt="" />
A Wise man once said, Wherever you go........there you are
Bone stock 90 Trooper 2.6, 5 speed. With the aerodynamics of a brick, and the power to match.
2000 Chevy Tracker, also bone stock, well, at least until it's paid off!!!
Re: interior brake noises ? [Re: rh71] #291306 07/25/03 01:02 PM
DieselBob Offline
My Trooper started making a creaking noise about 6 months after I bought it. My noise was comming from under the dash area but not everytime I would depress the brake pedal. I removed the brake pedal pivot bolt and the pin for the master cylinder rod, cleaned the assembly and re-lubed the bolt and pin and no more noise. <img src="/forums/images/graemlins/smile.gif" alt="" />
Bob
"You can't expect to wield supreme executive power just 'cause some watery tart threw a sword at you."
02 Trooper S, TOD, Aisin Hubs, FJORD Blue, ARB 3444070 Winch Bar. Dueler A/T REVO LT265/75R16
Re: interior brake noises ? [Re: troopinstile] #291307 07/25/03 02:12 PM
I have the same problem with my 91. I have tried all kinds of pads. No luck. I look at it as a reverse warning system like commercial trucks have. <img src="/forums/images/graemlins/grin.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6190 MB (Peak: 0.7227 MB) Data Comp: Off Server Time: 2026-06-21 19:04:54 UTC
