Isuzu d44 5.38 install & no-slip wear report #291969 07/26/03 11:42 PM
rodeo_chris Offline OP
Just got done getting my r&p installed. Love the power. I can actually pull hills in 5th under 2k rpm.
Problems:
The inner pinion bearing on the stock gearset is smaller in outer diameter than the bearing I got with my 5.38 dana gearset. Luckily the stock one showed almost no wear so we stuck it back in there.
Also decided to ditch the ABS ring rather than trying to modify the new carrier to make it work.
Overall, it went well. I'm anxious to get it out on the interstate to see what my rpm's are like with the 33's, but I have to get a few more miles on it first.
Front axle should be ready to pick up tuesday.
-chris
94 Rodeo, 35's, 5.38's, locked F&R, Rocker bar on one side, other side in garage
96 Tacoma, DD, pre-dented
Re: Isuzu d44 5.38 install & no-slip wear report [Re: rodeo_chris] #291970 07/27/03 04:52 PM
I also want to add that even though my powertrax no-slip rear locker only has about 25k miles on it, it was in perfect condition.
This was great news because I've been experiencing a loud, I mean over the radio, grit you're teeth, shake the <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> end of the truck loud, popping noise coming from the rear of the truck and was afraid it was the no-slip. The noise and shaking of my truck usually happens on the 1-to-2 shift while going through a turn. I found that I have an axle shaft bearing on it's way out on the passenger side, that is letting the shaft have just a little too much play. Replacing that bearing as well as my leaking axle seal(at least they weren't on opposite sides <img src="/forums/images/graemlins/kewl.gif" alt="" />) is gonna happen sometime in the next few months. I've located a few complete axle shafts at a local junk yard for $75, so I'll probably go that route and swap the whole shebang out.
-chris
Re: Isuzu d44 5.38 install & no-slip wear report [Re: rodeo_chris] #291971 07/29/03 02:40 AM
fred1980 Offline
How are the 5.38 gears working out so far. I'm pretty sure that their great off-road but what are the on road characteristics? I guess I'm asking if your truck is at 3000rpm's or what not when driving 60 down the highway. How about gas mileage? I ask cause I want to get 35's soon and know that the stock gearing in my truck is not going to cut it power-wise. Just hate being passed up on a steep hill by trucks pulling trailors all the time <img src="/forums/images/graemlins/notooth.gif" alt="" /> and I only have 33's now. Till later.
Fred R.
97 ZJ, 5" Long Arm Lift, Beadlocked 35's, 231/D300 Doubler, Locked Front & Rear (Narrowed HP D44 & F8.8), ARB Bull Bar & 9K winch, 1-Ton Hydro-assist steering, "Custom" body work and some other goodies... PICS
Re: Isuzu d44 5.38 install & no-slip wear report [Re: fred1980] #291972 07/29/03 03:39 AM
Fred R.
I love these gears. I accidently started the truck in 2nd today on a slight hill and didn't even reallize it until I got ready to change gears. Haven't been able to do that in a while.
As for the rpm's on the interstate, I read on Randy's Ring and Pinion website not to drive over 55mph for the first 500 miles so I wont know for a while. Don't know how crucial that is, but I don't want to push my luck. My speedo is way off, so I need to figure that out as well. I'll get back to you on the interstate rpm's though. I was running around 3000rpm's on the interstate before doing 65, guessing 70 as actual speed. I'll probably just slow down some to keep the rpm's more managable.
I will probably end up putting 35's on there eventually, just have a thin wallet right now and am trying to find 2 used 33's to replace my 'super slickers' on the front to tie me over.
-chris
Re: Isuzu d44 5.38 install & no-slip wear report [Re: rodeo_chris] #291973 08/01/03 02:06 AM
Here's a damage report on the most important thing right now, my wallet.
Got the rear gears installed for $160. I ended up helping the guy pull the shafts carrier out.
Front set me back $150 plus $25 for a bearing that I had supplied the wrong one. I was suprised that they had given the axle a fresh coat of black paint, that's gonna mess up my neon underbody powdercoating paint scheme <img src="/forums/images/graemlins/bird.gif" alt="" />
On a side note, has anyone else had fitment trouble with the lockright in the front 10-bolt? Gear guy said he had to clearance the carrier slightly to get it to fit.
As for the highway rpm's, in a 55mph zone today where I'm guessing the cars around me were doing 55-60mph, I was registering 65mph and about 27-2800rpm's, so yes rpm's at 65-70mph actual speed are gonna suck really bad but I think I can live with it for a few months before putting 35's on there.
-chris
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6118 MB (Peak: 0.6950 MB) Data Comp: Off Server Time: 2026-11-16 08:42:35 UTC
