alternator question #292413 07/28/03 06:08 AM
Rabichulo Offline OP
hey does anyone have a larger amp alternator? if so, how? i have yet to find one that will bolt into my gen1 2.6 or my 3.0... any help would be greatly apreciated.... <img src="/forums/images/graemlins/shocked.gif" alt="" />
Re: alternator question [Re: Rabichulo] #292414 07/28/03 06:18 AM
I did a 160a conversion on mine. About 3 months ago, I did it, then posted it with photos so you can probably do a search on it.
Others here will tell you to use the Starion unit which is either 70 or 75a but at best, a factory fresh unit will put out 65 on a good day with all the planets aligned.
Others will also say use some esoteric RX-7/Mazda Millenia or etc. alt but they are for car use and don't handle the cont. amps very well, get hot, and are very expensive to replace.
Make the bracket and put a good old GM/Delco whatever alt. in there (not to get into it Kary <img src="/forums/images/graemlins/wink.gif" alt="" />) and that way, they are cheap, reliable,powerful, and ALWAYS avail at any automotive store in the country.
Jason
Re: alternator question #292415 08/02/03 09:04 AM
i heard a rumor that just putting a larger diameter pulley on your alt will increase the output... does this work? if so... wouldn't it cause other problems? electrical isn't my forte... <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: alternator question [Re: Rabichulo] #292416 08/03/03 04:13 AM
Big Blue Offline
Max output, is just that. No pulley will change it. If you go to a smaller pulley, you may increase your output at idle. That will depend on the alternator, and how the regulater is designed, and of course, your idle speed. I have recently seen several Ford alternators off later Tempos, that appeared to be a bolt on, and are rated at 95amps. But 2.6 guy's check it out first, the stock alternator has an output wire to trigger the choke relay, and these may not. Just stay away from the GM CS 130 series, as they are not what they should be. <img src="/forums/images/graemlins/wink.gif" alt="" />
Kary
1987 Mitsubishi Pajero "Modified"
The other original Mitsu brother
Northwest Trailmaster
Re: alternator question [Re: Rabichulo] #292417 08/03/03 07:00 AM
liquidium Offline
Have you looked into Jacobs Electronics? I think their alternators are designed to be bolted to anything, anywhere. Unless I'm wrong, the (unwired) stock alternator can be left in place. Or maybe I'm thinking of coils.
97 Montero SR: Factory rear locker, 3.5 L 24 Valve V6, ActivTrac 4wd (Love it) , 3 way suspension, four wheel disk brakes, 32x11.50 Pirelli Scorpion ATs
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6070 MB (Peak: 0.6680 MB) Data Comp: Off Server Time: 2026-11-03 12:24:09 UTC
