3'rd gen slant #294089 07/29/03 05:44 PM
Swede Offline OP
Just curious if anyone else noticed a slight lean to the drivers side on their 3rd gen? My '98 4Runner had a little plastic block in the front left coil between the 4th and 5th loop. I took it out a week ago and noticed a slight 1/4" - 3/8" lean to the drivers side. Just wondering if this is normal, or do I have to explain to the wife why "we need the new OME suspension", and then "see how much higher it sits? Geez that old suspension was really bad!"
'98 4Runner, SR5, V-6, 5-speed, 35" Baja Claws, 17x9 Eagle Alloys, E-Locker, 3" Susp Lift, 3" Body Lift, Elbow mod, Deckplate Mod, "D" gasket mod, Silverstars, Headlight Film, 67" TG Sliders...
Next on the list: 4:88 gears
Re: 3'rd gen slant [Re: Swede] #294090 07/29/03 06:14 PM
Darren Offline
This is normal.
However, you will still need OME suspension. <img src="/forums/images/graemlins/notooth.gif" alt="" />
OME stuff won't cure the offset weight however. You would have to use some type of spacer or get adjustable coil-overs up front and add weight to the higher side in the rear, the latter of which I have done and sit identical from side to side now. No biggie otherwise. Even when mine was "slanted," I couldn't see a difference. Maybe you can though.
2002 4Runner
MyColorado.org (CO landscapes, destinations & trail reports)
Re: 3'rd gen slant [Re: Swede] #294091 07/29/03 07:47 PM
Just get he springs to fix it and install a 10" sub and box on the passenger side of the cargo area to level it out like I did... lol <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 3'rd gen slant [Re: Darren] #294092 07/29/03 07:47 PM
Mine did that and it pissed me off because my Pathfinder did the exact same thing, only on the other side. I thought it was a factory problem on the Nissan, so finding the same thing on the Toy pissed me off big time.
I think Toyota engineers put the same spring rates on the left and right side, but the left side has to support the gas tank, the front driveline, the steering column, and the frequent movement from the driver hopping in/out, and the weight of the drive himself.
On my Downey lift, there is a ? inch spacer on the left side to compensate for that. It sits level now.
Re: 3'rd gen slant [Re: Swede] #294093 04/03/04 08:57 AM
I thought I was crazy for thinking this also about the slant. I'm glad I found out I'm not. I wish Toy would fix this problem. Are aftermarket Coils made different to level it out? Any suggestions? I need to replace my original front coils. I just put on the rear PP springs (NICE). Next is to get some Bilsteins.
Re: 3'rd gen slant #294094 04/04/04 03:50 AM
larsdennert Offline
The left and right OEM coils are different to account for the weight. Possibly someone swapped them accidently when they did the shocks? Aftermarket coils are all the same.
Re: 3'rd gen slant [Re: Swede] #294095 04/04/04 06:18 AM
The slant is THE reason I am online at this very moment. I have noticed it before but blew it off as an optical illusion. Tonight I measured and discovered about a quarter inch difference.... and now it will irritate me until I correct it.
Does Toyota sell a spacer for the stock springs?
Glad to know I'm not seeing things and I'm not the only one.
Re: 3'rd gen slant [Re: Swede] #294096 04/05/04 07:34 PM
How did the plastic block get there in the coils? Was it like that from the dealer? And... does anyone still use original Toy front coils?
Re: 3'rd gen slant #294097 04/08/04 11:56 PM
anyone? Anyone?
Re: 3'rd gen slant [Re: Swede] #294098 04/09/04 05:43 AM
If you were to order the OME's, the drivers side spring should be a tad longer than the passenger to accomodate for the driver and gas tank.
One thing to keep in mind, these springs are made in Australia, ignore whatever labels are on the springs and ensure the taller goes on the drivers side.
Best of luck!
Mike
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6202 MB (Peak: 0.7267 MB) Data Comp: Off Server Time: 2026-11-16 08:42:28 UTC
