spool #302323 08/15/03 06:58 PM
JOEDIRT Offline OP
I've searched so lets just get that out of the way. I have seen about 10 posts that deal with a spooled or lincoln locked rearend.
I want to hear from people who have one or had one. No opinions. I now the downside of chowing tires and turning on raod. that doesn't bother me.
I run retreads. What I don't know is how much rear axle sutff will oyu brake running this. Bearings, r&p, etc.
I'm looking at getting a yukon full spool. I have a d44. This would be my daily driver. I just don't like the
squirlyness of lockers. <img src="/forums/images/graemlins/rodent.gif" alt="" /> Thanks everybody. <img src="/forums/images/graemlins/cheers.gif" alt="" />
97 TJ SE, intake, baja wheels, 31" mudders
Stripped down to a rollin gas can.
Re: spool [Re: JOEDIRT] #302324 08/15/03 07:36 PM
if you want the most info talk to Matt form Indy, he will give you all you ever needed to know about it, Im buying a spooled d44 this week and I could not be happier
Re: spool [Re: JOEDIRT] #302325 08/15/03 07:49 PM
RobG Offline
most people here running welded diffs and in 12-bolts not D44s. i don't know of anyone running a full spool. And i can only recall one who's blow up their rear end because of it and that was rcbob with his welded 12-bolt. lost some R&P teeth while doing a parking lot manevor on the pavement.
It definitely add more stress to you axle, especially when taking tight corners on hard traction surfaces (parking lot manevors). you didn't mention what size tire you are running, but adding a full spool to a D44 i'd say you're pretty safe into the 33-35" tire area... i wouldn't worry about it. how much you break will be a combination of the size tire you're running, driving style, and available traction.
D44 lincoln (well, miller actually) locker i welded up:
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 38x13 TSLs, spooled D60 front, 14bff rear locked by detriot, high steer w/ hydro, dual Isuzu tcases.
Re: spool [Re: RobG] #302326 08/16/03 05:41 AM
I welded mine very similar to Robs. I run 33" muds, its my daily driver, I tow a 3400lb boat and a 2500lb trailer, and I love it.It barks a bit when cornering tight ie parking lots, but besides that its as quiet as a mouse... It drives a little "differently" now, and a welded or spooled rear eats power because the axles are fighting each other all the time, but if you dont mind quirky road manners its the way to go... My rear tires are still wearing slower than my front??? for some odd reason so I dont have any complaints about tire wear either <img src="/forums/images/graemlins/grin.gif" alt="" />
Re: spool [Re: JOEDIRT] #302327 08/16/03 08:14 PM
JOEDIRT Offline OP
I have also been considering a lockright. However I was thinking that a locker might do more damage to the driveline than a spool. blacklash and all. The whole reason for this is lack of money. so no arb or ox. I have a V6 and a 5 speeed, and run 285/75/16 265's right now.
<img src="/forums/images/graemlins/bird.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: spool [Re: JOEDIRT] #302328 08/16/03 10:18 PM
Banchi105 Offline
I know Im quite the newbie when it comes to this but:
What exactly is a spool & how does it work?
Thanks!
Re: spool #302329 08/17/03 03:24 PM
A few years ago, I sometimes drove with a guy who also welded his rear diff., and he complained of this. At the time, we attributed it to the rear 'pushing' the front in turns, and scrubbing the tires sideways a little more than usual on the black top.
I can't say whether this is a definite cause, though.
--Bighorn--
Re: spool [Re: Banchi105] #302330 08/18/03 07:53 PM
RobG Offline
A spool is nothing more than a means of connecting the two axle shafts so they turn at identical rates (locked together). This defeats the differential action of your axle.
There are three types of spools, a welded diff (aka lincoln locker, see pict above), a minispool (replaces spider gears inside carrier), and a full spool (replaces the actual carrier).
-Rob
Robert Gorrell
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6207 MB (Peak: 0.7199 MB) Data Comp: Off Server Time: 2026-11-16 01:19:38 UTC
